How to set“enable-last-sample” property of fakesink in deepstream? Is gst_base_sink_set_last_sample_enabled (GstBaseSink * sink, gboolean enabled) right? If right,which is the .h file?
Do you mean how to set gstreamer plugin property with c code?
Please use “g_object_set()” function to set gstreamer element property.
This is basic Gobject and gstreamer programming skill. Please refer to Gobject and gstreamer resources.
GObject: GObject Reference Manual (gnome.org)
Basic tutorial 2: GStreamer concepts
This is deepstream forum, let’s focus on deepstream topics.
Thank you for the reply.
Yes.I use g_object_set(G_OBJECT(sink),“enable_last_sample”,false,NULL); but it seems not work.
I want to save image in deepstream, and it succeed.
But I do not want to show the video, so I make sink element of gstreamer to “fakesink”, but after save 3 image, the program exists with error.
The error is below:
ERROR from element qtdemux0: Internal data stream error.
But it is ok when sink is “nveglglessink”
• DeepStream Version
• TensorRT Version
