To address the issue of swapping CSI1D0 lanes on CAM0 for the ADV7282m device to work with the Jetson Orin Nano Dev kit and NVIDIA carrier board, we need to delve into the device tree configuration.
The device tree is a data structure that describes the hardware components of a system, including the CSI (Camera Serial Interface) lanes. In your case, you’re experiencing issues with CAM0 due to the swapped CSI1D0 lanes.
To swap the lanes in the device tree, you’ll need to modify the lanepolarity property. However, as you’ve mentioned, setting lanepolarity with different values hasn’t had the desired effect.
Let’s take a closer look at the lanepolarity property and its possible values:
lanepolarity is a property that defines the polarity of the CSI lanes.
- The possible values for
lanepolarity are:
normal (default): The CSI lanes are not inverted.
inverted: The CSI lanes are inverted.
To swap the CSI1D0 lanes, you’ll need to set the lanepolarity property to inverted for the specific lane. However, since you’ve already tried setting lanepolarity with different values without success, it’s possible that the issue lies elsewhere.
Here are a few potential solutions you can try:
- Verify the device tree syntax: Ensure that the device tree syntax is correct and that the
lanepolarity property is properly defined.
- Check the CSI lane configuration: Verify that the CSI lane configuration is correct and that the lanes are properly connected to the ADV7282m device.
- Use the
csi-lane-swap property: Instead of using lanepolarity, try using the csi-lane-swap property to swap the CSI lanes. This property is specific to the NVIDIA Tegra platform and allows you to swap the CSI lanes.
- Consult the NVIDIA documentation: Refer to the NVIDIA documentation for the Jetson Orin Nano and NVIDIA carrier board to ensure that you’re using the correct device tree properties and syntax.
To provide a more comprehensive solution, I’d like to compare the device tree configuration for CAM0 and CAM1. Could you please provide the device tree configuration for both CAM0 and CAM1, including the lanepolarity property and any other relevant configuration options?
Additionally, have you tried using the csi-lane-swap property to swap the CSI lanes? If so, what were the results?
By comparing the device tree configurations and exploring alternative solutions, we can work together to resolve the issue and get the ADV7282m device working with the Jetson Orin Nano Dev kit and NVIDIA carrier board.
