Right now when I run the pipeline there’s a lot of INFO
messages like:
Now playing:
gstnvtracker: Loading low-level lib at ../lib/libnvds_nvdcf.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is ON
[NvDCF] Initialized
0:00:01.055599330 28854 0x55ba0f683780 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: mm1_162: broadcasting input0 to make tensors conform, dims(input0)=[1,38,19][NONE] dims(input1)=[256,19,19][NONE].
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: mm2_162: broadcasting input1 to make tensors conform, dims(input0)=[256,38,19][NONE] dims(input1)=[1,19,38][NONE].
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: mm1_170: broadcasting input0 to make tensors conform, dims(input0)=[1,76,38][NONE] dims(input1)=[128,38,38][NONE].
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: mm2_170: broadcasting input1 to make tensors conform, dims(input0)=[128,76,38][NONE] dims(input1)=[1,38,76][NONE].
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:37 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
And so on and so forth. Is there a way to filter this out? I’m currently using a custom .so
file taking a reference from libnvdsinfer_custom_Yolo.so
so in the NvDsInferYoloCudaEngineGet
is there a way to set the ILogger
severity level (since it’s not static
I can’t set it outside the scope)? Furthermore, there’s also GStreamer INFO messages that I’d like to get rid. Is there a way to do that?
• Hardware Platform: NVIDIA T4
• DeepStream Version: 5.0
• TensorRT Version: 7
• NVIDIA GPU Driver Version 440
