Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
[*] DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Host Machine Version
[*] native Ubuntu 18.04
other
Hi, team,
I am trying to add serializer Max96717F camera in NvSIPL. Max967167F only works in 3Gbps mode. I try to modify CNvMMax96712.cpp, but it looks not worked. I think Nv only opensource CNvMMax96712.cpp but not use it in the opensource part. And CNvMMax96712.cpp already build in libnvsipl_devblk.so right? So how can i set Max96712 in 3Gbps mode.
Hi,@VickNV , it’s not MAXIM’s issue. I think there is a bug in NvSIPL.
NvSIPL’s framework support GMSL2 and GMSL1, and GMSL2 only support 6Gbps, But GMSL2 has 6Gbps and 3Gbps , and in function static NvMediaStatus SetLinkMode( DevBlkCDIDevice *handle, LinkMAX96712 link)
only can choose GMSL1 3Gbps and GMSL2 6Gbps. There is no option for GMSL2 3Gbps.
if i set LINK_MODE_GMSL1 in function CNvMDeserializer::LinkMode CNvMMAX96712_96XXXCameraModule::GetLinkMode()
the program will excute the function NvMediaStatus MAX96712SetDefaults( DevBlkCDIDevice *handle)
If i set LINK_MODE_GMSL2 , the function wont be excuted. Thats super Confusing.
Whats the estimated release time of upcoming release?
CNvMMax96712::Init() is not called in both MODE set. The funciton MAX96712CheckLink looks like only called in LINK_MODE_GMSL1 mode. I think there is a copy of class CNvMMax96712 in libnvsipl_devblk.so ? Because i can grep evey printf message in libnvsipl_devblk.so.
@VickNV Yes, SIPLStatus CNvMMax96712::CheckLinkLock(uint8_t linkMask) never called. I tried print log in that function and gdb debug make break for CheckLinkLock. They both show nothing
The function is also called in
~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_HW_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/samples/nvmedia/nvsipl/devblk/cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_*.cpp.
You can have a check on them.
