Hi All,
I want to set my -maxrregcount is 20 which now takes 40 and gives 0.25 occupancy.
For this I go through
Project->properties->CUDA->command Line
write in the box of Additional options -maxrregcount =20 .
But when I rebuild and execute my project using profiler still get register per thread is 40 .
My question is how to set my -maxrregcount to 20?
When I set option Project->properties->CUDA->Advanced-> maximum register to 20 then i get error
Could any one help?
Nico
3
You may want to mention which IDE you’re using :)
N.
It is either the space between “maxrregcount” and “=”
OR
You should actually specify “–maxregcount”. Another “-” is required, I think.
Thanks Quoc Vinh , Sarnath and Nico , “–maxrregcount=20” gives correct output.
