How to Set Network Proxy in NVIDIA Jetson 4Gb module?
i am working in institute which is having proxy in the network but i have followed standard ubuntu procedure, such apt.conf, brash file adjustment etc.
I can’t personally answer, but anything on Ubuntu 18.04 will be correct (a Nano won’t be any different than a desktop PC with Ubuntu 18.04).
If you run into a specific issue, e.g., something in one of those does not work, then you can still ask questions here, but those should get you started.
