How to set partition config xml file to auto format the UDA partition
I have data partition as below, and I want format/erase the data partition every time programming.
may I know any attribute or setting can be done to format data partition to ext4 reprogramming, currently when reprogram, data partition is not erased.
thanks
        <partition name="UDA" type="data">
            <allocation_policy> sequential </allocation_policy>
            <filesystem_type> basic </filesystem_type>
            <size> 1825361100800 </size>
            <file_system_attribute> 0 </file_system_attribute>
           <allocation_attribute> 0x808 </allocation_attribute>
            <percent_reserved> 0 </percent_reserved>
            <align_boundary> 16384 </align_boundary>
            <description> **Required.** This partition may be mounted and used to store user
              data. </description>
        </partition>
Hi jiangpen,
What do you mean about “every time programming”?
Do you mean that you want to erase this partition after reflashing?
@KevinFFF I am using the custom board for Orin, and Jetpack is Jetson Linux 32.7.1 .
Now when I reprogram the board, the UDA (data partition ) is not erased and keep untouched.
I want reflash the board, the data partition also erase and clear . thanks
It is not the expected result to me since AGX Orin may not work with R32.7.1.
Please share the result of the following command on your board.
$ cat /etc/nv_boot_control.conf
$ cat /etc/nv_tegra_release
How did you flash the board?
As my understanding, the current flash process will erase/format the disk so that your custom data in UDA would not be preserved.
