How to set polygon roi in nvdspreprocess
**• Hardware Platform (Jetson / GPU)**jetson agx orin
• DeepStream Version6.4
• JetPack Version (valid for Jetson only) 6.0 DP
• TensorRT Version
• Issue Type( questions, new requirements, bugs) questions
Currently, nvdspreprocess does not support setting polygon roi.
Can you share the reason? Maybe there is another workaround. if you want to do roi-filtering or Overcrowding Detection, nvdsanalytic 1 plugin already supports polygon setting.
How do I get the set polygon roi in a subsequent node callback, for example in osd’s src pad callback
If you plan to use nvdsanalytics, please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-nvdsanalytics-test/deepstream_nvdsanalytics_meta.cpp, The ROI will be attached to NvDsAnalyticsFrameMeta.
You also can customize your own usermeta.
I don’t see in this example where I can get the roi of the polygon,Can you share the following code
The parse_nvdsanalytics_meta_data function in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-nvdsanalytics-test/deepstream_nvdsanalytics_meta.cpp.
The user meta data type is NVDS_USER_FRAME_META_NVDSANALYTICS
This part of the code actually shows only these types, I want to get the line coordinates of the polygonal roi
Sorry, It looks like some information is missing from NvDsAnalyticsFrameMeta, This is a issues.
Other options can be considered.
1.Parse config_nvdsanalytics.txt when you need to get ROI
2.nvdsanalytics is opensource, add the ROI coordinate to framemata in function attach_framemeta_analytics_metadata.
