How to set ProfilingVerbosity::DETAILED in Deepstream?
I use this example from NVIDIA yolo_deepstream/deepstream_yolo at main · NVIDIA-AI-IOT/yolo_deepstream · GitHub to generate fp32 model. But when I export graph.json file, it only contains layer name. How to set ProfilingVerbosity::DETAILED in Deepstream to get full graph.json later? I search for in /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-app/ but I didn’t find where I need to set. Sorry for unfamiliar with C++.
I also tried changing
    void setProfilingVerbosity(ProfilingVerbosity verbosity) noexcept
        // mImpl->setProfilingVerbosity(verbosity);
        mImpl->setProfilingVerbosity(ProfilingVerbosity::DETAILED);
But it is affected.
Is there any way to set it in deepstream_config.txt? Thanks.
Do you mean to generate TensorRT model engine?
@Fiona.Chen Sorry for confusing. I mean that I used the repo yolo_deepstream/deepstream_yolo at main · NVIDIA-AI-IOT/yolo_deepstream · GitHub for generating fp32 engine model, but in deepstream default ProfilingVerbosity is set to kLAYER_NAMES_ONLY. I want to set ProfilingVerbosity::DETAILED when run Deepstream app, but I dont know how to set it.
I tried changing TensorRT source code at /usr/include/x86_64-linux-gnu/NvInfer.h as follow
        // mImpl->setProfilingVerbosity(verbosity);      // ORIGINAL
        mImpl->setProfilingVerbosity(ProfilingVerbosity::DETAILED);       // I change to this line
I don’t know which API Deepstream use to generate .engine model, trtexec? It seem not effect.
The reason I want to set ProfilingVerbosity::DETAILED when run Deepstream app is that I want to use TensorRT/tools/experimental/trt-engine-explorer at main · NVIDIA/TensorRT · GitHub to explorer my generated fp32 engine. Trt engine explore need full graph json file to have more information of layers. If I don’t set ProfilingVerbosity::DETAILED when run Deepstream app, graph json file only contains layer names, not contains information about weights, layer type…
I used this command to export profile json file and graph json file from generated .fp32 model
/usr/src/tensorrt/bin/trtexec --loadEngine=../fp32.engine --exportLayerInfo=graph.json --exportProfile=profile.json
You can add it in NvDsInferStatus
TrtModelBuilder::configCommonOptions() function in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/nvdsinfer_model_builder.cpp. And then rebuild the “libnvds_infer.so” in the directory /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/. Please read /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/README.
After that, the new “libnvds_infer.so” can be put in /opt/nvidia/deepstream/deepstream/lib/ to replace the old one.
Thanks. I will try it.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. This topic will be closed if there is no update. Thanks
