How to set the pin of pinmux spreadsheet to SFIO?
I need the orin module is adapted to the xavier bottom board.
The question is that how to use Orin’s RGMII interface.
I refered to Does Orin support 88E1512 PHY chip? - #18 by WayneWWW and didn’t know how to excute the 4th step.
Can you show me how to do it.
There is a customer usage on the spreadsheet which you can select the pin function.
Also, you can directly refer to the new adaptation guide but not the method I shared.
The document has been updated.
How to modify the pin to SFIO? Do you mean modify the color of pin?
You click the “customer usage” column and it can select the function… Please remember to use Windows host to open this file.
“Customer usage” 那欄是可以下拉選東西的 . 記得要用Windows主機
I can’t find the the related item.The most like item is as following. Do you mean this?
Please try to select the third option in each row and column from eqos.
and completed the change as below.
The last request is to ensure that you point these files to the new board.conf.
I don’t know how to do it.
I write a error in the pinmux.dtsi deliberately, but there is no error in the burn process.
