How to set the variables in the global memory to zero effectively?
I am modifing my finite elment program to use cuda.
The main time consuming part in the program is the compuation of internal force of each node.
In cpu code, there are mainly the following steps
set FORCE to zero
loop on each element, and compute the force on each node of current element
summary the force together
According to this thinking , I made the folloing program.
[codebox]
#include <stdio.h>
#define BLOCK_NUM 1
#define THREAD_NUM 10
#define NUM_ELE 4
#define NUM_NOD 18
#define NC(j,N) *(NC+(N-1)*8+j-1)
#define FORCE(N) *(FORCE+N-1)
global void internal_kernel(int* , float *);
int main(void)
int NC[8*NUM_ELE];
float FORCE[18];
NC(1,1)=1 ;
NC(2,1)=3 ;
NC(3,1)=9 ;
NC(4,1)=7 ;
NC(5,1)=2 ;
NC(6,1)=4 ;
NC(7,1)=10 ;
NC(8,1)=8 ;
NC(1,2)=3 ;
NC(2,2)=5 ;
NC(3,2)=11 ;
NC(4,2)=9 ;
NC(5,2)=4 ;
NC(6,2)=6 ;
NC(7,2)=12 ;
NC(8,2)=10 ;
NC(1,3)=7 ;
NC(2,3)=9 ;
NC(3,3)=15 ;
NC(4,3)=13 ;
NC(5,3)=8 ;
NC(6,3)=10 ;
NC(7,3)=16 ;
NC(8,3)=14 ;
NC(1,4)=9 ;
NC(2,4)=11 ;
NC(3,4)=17 ;
NC(4,4)=15 ;
NC(5,4)=10 ;
NC(6,4)=12 ;
NC(7,4)=18 ;
NC(8,4)=16 ;
int *dNC;
float *dFORCE;
cudaMalloc( (void**)&dNC,NUM_ELE*8*sizeof(int));
cudaMalloc( (void**)&dFORCE,NUM_NOD*sizeof(float));
cudaMemcpy(dNC,NC,NUM_ELE*8*sizeof(int),cudaMemcpyHostToDevi
ce);
// call compuation kernel first time
internal_kernel<<<BLOCK_NUM,THREAD_NUM>>>(dNC,dFORCE);
cudaMemcpy(FORCE,dFORCE,NUM_NOD*sizeof(float),cudaMemcpyDevi
ceToHost);
for(int i=1;i<=NUM_NOD;i++)
printf("NOD %d %f\n",i,FORCE(i));
//call computation kernel second time
ceToHost);
cudaFree(dNC);
cudaFree(dFORCE);
return 0;
global void internal_kernel(int* NC, float *FORCE)
const int tid=threadIdx.x;
const int bid= blockIdx.x;
const int THREADS=blockDim.x;
const int BLOCKS=gridDim.x;
float FORCE_ELE[8];
//initialize the force_int value
for(int i=bid*THREADS+tid;i<NUM_NOD;i+=BLOCKS*THREADS)
*(FORCE+i)=0.0;
__syncthreads();
//compute internal force
for(int NELE=bid*THREADS+tid+1;NELE<=NUM_ELE;NELE+=BLOCKS*THREADS)
for(int j=1;j<=8;j++)
FORCE_ELE[j-1]=NELE*10.0+j*1.0;
int NOD;
NOD=NC(j,NELE);
FORCE(NOD)=FORCE(NOD)+FORCE_ELE[j-1];
// printf(“NELE: %1d J:%1d NOD:%2d \t FORCE_ELE:%10.1f\t FORCE:%10.1f\n”,NELE,j,NOD,FORCE_ELE[j-1],FORCE(NOD));
__syncthreads();
return ;
[/codebox]
As the FORCE array in global memory should be initilized to zero, I want to do this on GPU side but not on CPU side to improve efficiency.
(If initialized on CPU side, lots of zeros have to be copied from host to device.)
If I use many threads but only one block to perform the computation, as the __syncthreads() can be used within a block, the results are correct.
But when more blocks were used, as the performing order for each block are random and can not use _syncthreads between blocks, the above will lead to wrong result.
Anyone can give me some advice to solve this problem?
Thank you in advance.
