How to set the visibility of a prim to a specific camera (in a multiple camera case)?
Hi, I have a problem about prim visibility to cameras.
Simplify my problem to this case: there are 2 Cameras X, Y and 2 prims A, B in a scene. I want the camera X only render prim A and camera Y only render prim B. That is, wherever the camera X is, prim B will never appeared in its rendered image, the same for Y.
I know that it is easy for to set global visibility for prim A/B, which can solve the problem in a ugly way: InVisible(B) → Camera X shot → Visible(B) → InVisible(A) → Camera Y shot → Visible(A) …
For the real case, there are multiple cameras and each camera needs to focus on different collection of prims. I wonder if there is a simple way to make this, thanks.
Hi mulplue,
Maybe write a script can help you for this task:
dynamically disable prim with name rules.
==========sample code=========
code 1:
from pxr import Usd, UsdGeom
Load the stage with a given USD file
stage = Usd.Stage.Open(“path/to/your/file.usd”)
Define the rule for names you want to search for
def name_matches_rule(name):
# Here you can define your own logic
# For example, turn off all prims with “temp” in the name:
return “temp” in name
Iterate through all prims in the stage
for prim in stage.TraverseAll():
if name_matches_rule(prim.GetName()):
# Set the visibility attribute to “invisible”
UsdGeom.Imageable(prim).GetVisibilityAttr().Set(UsdGeom.Tokens.invisible)
Save changes
stage.GetRootLayer().Save()
code 2:
from omni.isaac.core.utils.prims import set_prim_visibility
set_prim_visibility(prim, False)
Hi Jeffli, thanks for your reply!
I’ve read your code, however, what I want is not globally set the visibility property. For Example, when I use your scipt to turn off prim “A”, both camera “X” and “Y” can’t see “A”.
The ideal situation is: camera “X” can only see prim “A”, and camera “Y” can only see prim “B”, at the same time&stage. This can’t be archieved by set global visibility(like set_prim_visibility(prim, False)).
A possible way may like this: set all prims visible, but change the renderVisibility property during rendering(I found this property in usd doc, but I didn’t find related functions in pxr.UsdRender). So that we can set different redering process for camera “X” and “Y” to make them see different prims at the same time. However, I don’t know how to make this in isaac sim.
Hi mulplue,
pxr usdgeom has such api,renderVisibility UsdGeom module — pxr-usd-api 105.1 documentation (nvidia.com),
if the given prim is a primitive geometry object prim, you may use this api
Hi Jeffli,
I have read the doc carefully, but I still don’t know how to apply the renderVisibility attribute to a specific camera. Are there any code examples? In my case, the code framework is like this(running in script editor):
import omni
import numpy as np
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.sensor import Camera
import omni.isaac.core.utils.numpy.rotations as rot_utils
# create cube a and b
path_a = "/World/cube_a"
path_b = "/World/cube_b"
cube_a = DynamicCuboid(
    prim_path=path_a,
    name="fancy_cube",
    position=np.array([2.0, 0, 0]),
    color=np.array([0, 0, 1.0]),
cube_b = DynamicCuboid(
    prim_path=path_b,
    name="fancy_cube",
    position=np.array([-2.0, 0, 0]),
    color=np.array([1, 0, 0]),
# create camera x and y
camera_x = Camera(
    prim_path="/World/camera_x",
    position=np.array([2.0, 0.0, 50.0]),
    frequency=20,
    resolution=(256, 256),
    orientation=rot_utils.euler_angles_to_quats(np.array([0, 90, 0]), degrees=True),
camera_y = Camera(
    prim_path="/World/camera_y",
    position=np.array([-2.0, 0.0, 50.0]),
    frequency=20,
# attach renderVisibilityAPI to cube a and b
render_vis_a = UsdGeom.VisibilityAPI.Apply(stage.GetPrimAtPath(path_a))
render_vis_b = UsdGeom.VisibilityAPI.Apply(stage.GetPrimAtPath(path_b))
render_vis_a.CreateRenderVisibilityAttr()
render_vis_b.CreateRenderVisibilityAttr()
# make cube_a only visible to camera_x
# TODO
# make cube_b only visible to camera_y
# TODO
I can’t get any reference to help me write the #TODO part, can you give me some supports? Thank very very much!
Hi mulplue,
Sorry for late response, not sure one camera can render related to a specific camera, let me check internally and sync up later.
Hi mulplue,
Check internally, render to specific prim is not supported.
Thanks! Would Isaac Sim add this property in the recent future?
