I read the yuv20 720p30 file from the hard disk and encode ->decode. I found that the decoder capture the first frame when encoder capture the third frame. So the encoder is 3 frames faster than the decoder from now on.
Do tx2-nx decoder and encoder have low delay?Or how to make it narrow?
We support gstreamer and jetson_multimedia_api on Jetson platforms. For low-latency, you can enable the properties in nvv4l2decoder:
disable-dpb : Set to disable DPB buffer for low latency
flags: readable, writable
Boolean. Default: false
enable-max-performance: Set to enable max performance
and the properties in nvv42l2h64enc/nvv4l2h265enc:
maxperf-enable : Enable or Disable Max Performance mode
flags: readable, writable, changeable only in NULL or READY state
poc-type : Set Picture Order Count type value
Unsigned Integer. Range: 0 - 2 Default: 0
You can see the same properties in jetson_multimedia_api.
