How to set up build environment for building kernel ?
Dear Sir,
I have installed ubuntu14.04 -64bit on virtual machine, would you please tell me how to set up the build
environment for kernel building , is there any guide document? Thanks!
I want build kernel driver on TX2 board, the OS in TX2 is using JetPack-L4T-3.1-linux-x64.run
L4T document → Kernel Customization
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-2-ga
Beware that a VM is usually a problem when flashing or using it for package install. You may have to spend a lot of time figuring out how to configure the VM.
Thanks a lot!
I have built kernel and dtb success ,but I don’t know which dtb will be used on TX2 board, the dtb files are as follows:
ddot tegra186-quill-p3310-1000-a00-00-dsi-hdmi-dp.dtb
tegra186-quill-p3310-1000-a00-00-ape-cam.dtb tegra186-quill-p3310-1000-a00-00-edp.dtb
tegra186-quill-p3310-1000-a00-00-base.dtb tegra186-quill-p3310-1000-a00-00-imx274.dtb
tegra186-quill-p3310-1000-a00-00-base-mods-display.dtb tegra186-quill-p3310-1000-a00-00-no-rtcpu.dtb
tegra186-quill-p3310-1000-a00-00-dsi-dp.dtb tegra186-quill-p3310-1000-c03-00-base.dtb
Which one is for TX2 ?
tegra186-quill-p3310-1000-c03-00-base.dtb for default board configuration.
I want to delete sdmmc card write protect feature , where to change in dtsi file?
