How to set up orin nano 8G to boot into command line mode
I have a development board orin nano 8G module, and I want to boot into the command line mode.
I tried the following two commands to close the graphical interface, but the device will enter a black screen after restarting.
  • sudo systemctl disable gdm3
  • sudo systemctl set-default multi-user.target
The status I hope to get is to boot into command line mode instead of no display.
Hope this helps me solve this problem
To add, the JetPack version I am using is 5.1.1
Jetpack5 does not support command line mode.
Only GUI mode.
Thanks for the reply, but I have this requirement now. Can I achieve this function by modifying the kernel configuration or other methods?
Please upgrade to jetpack6 and it will be supported.
