How to set up the full build environment for NVIDIA Aerial™ Framework on GH200?
Hi NVIDIA Aerial team,
I am trying to build and use the NVIDIA Aerial™ Framework on a GH200 system, but I am not fully sure which host-side build environment is officially recommended for GH200.
My platform is:
Platform: NVIDIA GH200 / Grace Hopper
OS: Ubuntu 22.04.x
Architecture: arm64 / aarch64
Repository: aerial-framework
Build preset: clang-release
Command:
  cmake --preset clang-release
During the setup, I encountered several toolchain dependency issues step by step.
First, the system CMake version was too old:
CMake Error at CMakeLists.txt:16 (cmake_minimum_required):
  CMake 3.23 or higher is required. You are running version 3.22.1
After upgrading CMake, the next issue was missing Ninja:
CMake Error: CMake was unable to find a build program corresponding to "Ninja".
CMAKE_MAKE_PROGRAM is not set.
After installing Ninja and Clang, CMake was able to detect Clang 14:
-- The CXX compiler identification is Clang 14.0.0
-- The C compiler identification is Clang 14.0.0
-- The ASM compiler identification is Clang with GNU-like command-line
-- Found assembler: /usr/bin/clang
However, the configuration then failed because nvcc could not be found:
CMake Error at /usr/share/cmake-4.3/Modules/Internal/CMakeCUDAFindToolkit.cmake:104 (message):
  Failed to find nvcc.
  Compiler requires the CUDA toolkit. Please set the CUDAToolkit_ROOT
  variable.
My question is:
What is the complete recommended build environment for compiling NVIDIA Aerial™ Framework on GH200?
Could you please clarify the officially recommended versions for the following components?
1. Ubuntu version
2. Linux kernel version
3. NVIDIA GPU driver version
4. CUDA Toolkit version, including whether host-side nvcc is required
5. CUDAToolkit_ROOT path expected by CMake
6. CMake version
7. Clang / clang++ version
8. Ninja version
9. GCC / G++ version, if required
10. Python version
11. DOCA version, if required
12. MLNX_OFED / Mellanox driver version, if required
13. MFT version, if required
14. Recommended Aerial Framework branch or release tag
15. Whether the build is expected to be done directly on the GH200 host or inside an NVIDIA-provided container
It would be very helpful if you could provide a known-good version matrix for GH200, for example:
GH200 known-good build environment:
OS:
Kernel:
Driver:
CUDA Toolkit:
CMake:
Clang:
Ninja:
Python:
DOCA:
OFED:
MFT:
Aerial Framework branch/tag:
Container image, if applicable:
Also, if the recommended workflow is container-based, could you clarify whether the host still needs the full CUDA Toolkit with nvcc, or whether the CUDA compiler should only exist inside the container?
Thank you.
Hi @xudong.zhao
The installation requirements for Aerial FW are listed here:
Installation — Aerial Framework
Also note that for the runtime environment (to test fronthaul functionality with RU emulator), all configuration steps below are required:
Installing Tools on Grace Hopper MGX System — Aerial CUDA-Accelerated RAN
Thank you.
