How to setup and use distance sensor?
I have read the documentation but can’t figure out how to use a simple distance sensor in python.
My USD robot contains an IMU and a GenericSensor. The IMU is easily controlled using the omni.isaac.sensor.IMUSensor class however I can’t find a similiar way to use the generic distance sensor.
Is there a similar way to use distance sensors?
After trying to make it work somehow, the solution I found for a simple distance sensor is to create an empty XForm where the sensor should be and using “ray_cast()” to cast a ray and get the distance to the object that intersected it.
Mind that ray_cast() calculates the distance from the origin on the X axis only.
