How to setup hw isp to convert yuv sensor image to rgb888 using custom coefficients?
we want to convert yuv image from sensor to rgb using custom coefficients:
sensor --yuv–> VI → ISP --custon coefficients → RGB → SIPL ouput
is it possible to setup hw isp to do so?
ISP don’t support YUV sensor.
Maybe you can try below.
sensor->VI->nvvidconv->RGBA-> …
so, it’s only possible to use the vic engine to do the conversion?
Yes, that’s correct.
