How to show a dialog when power off button pressed?
I want to show a dialog when power off button pressed like ubuntu , want should I do?
hello mozzie,
this should pop-up after you long-press the power button. then you’re able to press volume button to select the controls.
may I know which JetPack release you’re working with? thanks
emm…I am using JetPack 4.4, actually I want to show my dialog, not the default dialog of Ubuntu gnome desktop. after uninstall the gnome desktop, when I push the power button, the system power off directly without showing any dialog, I think we can also customize a dialog like gnome when the power button is pressed.
Thank you.
hello mozzie,
you may have a try to add gpio-timed-keys; here’s kernel documentation for your reference, $L4T_Sources/r32.6.1/Linux_for_Tegra/source/public/kernel/nvidia/Documentation/devicetree/bindings/input/gpio-timed-keys.txt
I had read the document, but I only find how change the power button press time, it seems not suit my situation.
What I need is to show a dialog box when the power button is pressed. and the gnome desktop can do this without gpio-timed-keys. I guess they know where to add a script when the power button is pressed.
thank you .
hello mozzie,
I see, you would like to have power menu customization,
please check this page for Ubuntu desktop configuration by gsettings.
thanks
Thank you very much.
