Hi everyone.
**• | Hardware Platform (GPU)** |
**• | DeepStream 5.0** |
When I run this command to inference a video file from a tlt ssd object detection model:
deepstream-app -c deepstream_app_source1_detection_models.txt
it only shows the label of detected objects. How to append confidence value on the screen? which source could should be modified?
Appending confidence value to the labels as this video:
it should be mentioned for applying ssd inference I used these files:
- custom-lib-path=libnvds_infercustomparser_ssd_tlt.so in config_infer_primary_ssd.txt
- and libnvinfer_plugin.so.7.0.0 in /usr/lib/x86_64-linux-gnu/ path
