How to show the content of the sink plugin in jupyter?
Why does the sink plugin not show the output in jupyter. The script, deepstream_test_1.ipynb, has a plugin sink at the end of the pipline. The output video is not displayed in jupyter.
print(“Starting pipeline \n”)
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
This cell just output 2 words “Starting pipeline”. Should not the video been shown following? I am curious. If I want to show the output of the sink plugin in jupyter, how to deal with it?
• DeepStream Version
• TensorRT Version
The docker is:
nvcr.io/nvidia/deepstream 5.1-21.02-devel
deepstream-app version 5.1.0
DeepStreamSDK 5.1.0
CUDA Driver Version: 11.2
CUDA Runtime Version: 11.1
TensorRT Version: 7.2
cuDNN Version: 8.2
libNVWarp360 Version: 2.0.1d3
This cell
try:
loop.run()
except:
pass
just output 2 words “Starting pipeline”. I hope to demonstratce the output video of the sink plugin in jupyter. How to deal with it?
Can the deepstream sample application such as deepstream_python_apps/apps/deepstream-test1 at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub work and display video in the docker?
The sample [deepstream_python_apps/apps/deepstream-test1) work, but still donot display video in the docker:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file sample_720p.mp4
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
0:00:00.144573587 22888 0x3b50ed0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
Warning, setting batch size to 1. Update the dimension after parsing due to using explicit batch size.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:07.929096569 22888 0x3b50ed0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:07.934491354 22888 0x3b50ed0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Just stop here.
What is your docker command? Have you run “xhost +” before you run the docker container?
I can gedit file of the docker. So I have run “xhost +” before running the docker container. And export DISPLAY=:1 both in host and docker. So what is the wrong? Can provide any help?
I can not reproduce your error. Can you post your docker command?
Can you use sunlogin to test the demo?
Just deepstream_python_apps/apps/deepstream-test1, without any more command.
Yes. The sample can run in my docker and machine.
I once run the demo in docker terminal. But now it donot work in terminal and jupyter. My QQ is 40753152.
Please provide any useful information in this forum.
Your information are not useful. You donot provide any information. You just order to present the problem, even the details of the problem have been stated for many times. Please provide some useful help.
