How-to-solve-quot-failed-to-start-resize-sd-card-root-partition-and-filesystem-quot-
i had downloaded L4T Jetson Driver Package(R32.1) from Jetson Download Center and extract(L4T Sample Root File System) to rootfs dir
i used below command to flashing and booting the target device:
sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
the Jetson nano target device started successfully
but if i use source_sync.sh to download kernel sources(tag R32.1) and build successfully
i copy tegra210-p3448-0000-p3449-0000-a02.dtb to /kernel/dtb/ and Image to /kernel/
cp out/kernel_out/arch/arm64/boot/dts/tegra210-p3448-0000-p3449-0000-a02.dtb kernel/dtb/
cp out/kernel_out/arch/arm64/boot/Image to /kernel
then i flash to target device
the system could not be started and the error shown below:
“failed to start resize sd card root partition and filesystem”
Does anybody have a suggestion?
Hi corn.chen,
Could you move to latest release rel-32.3 and see if this issue is still?
If so, could you check whether this is causing by image or dtb?
