How to solve the error ?when I only recompile lib/nvdsinfer and install the libnvds_infer.so file, then run deepsream_test1, no inference result
Hardware Platform ( / GPU): 12.1
DeepStream Version: 6.3
TensorRT Version:8.5.3
NVIDIA GPU Driver Version (valid for GPU only):525.125.06
ubuntu 20.04
My problem is: when I only recompile lib/nvdsinfer and install the libnvds_infer.so file, then run deepsream_test1, no inference result.
How did you run it, docker or host, c or python? Can you share your command line?
Thank you for your reply. I run the program in host, C. The command line is ‘/deepstream-test1-app dstest1_config.yml’
I didn’t change the config file , the deepstream-test1 program, and gst-nvinfer program. Only compile the nvds_infer in lib folder and install the so file.
The deepstream-test1 program can run , but not show the inference resuls
Usually there is no problem, try the following command
cd /opt/nvidia/deepstream/deepstream-6.3/sources/gst-plugins/gst-nvinfer
make CUDA_VER=12.1 install
By the way, have you changed the code?
Hi, thanks for you reply. Follow the method you suggested,unfortunately it didn’t work. I didn’t change any code, just to compile the nvdsinfer in the lib folder, and install.
If I use the original library file in ‘/opt/nvidia/deepstream/deepstream-6.3/lib’, it worked fine.
I am not sure what happened, I haven’t encountered this problem could you try restarting?
