ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : command safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb” 5; sleep 5; finished with error
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:53 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : command terminated with error
14:49:54 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install ‘NVIDIA Container Runtime with Docker integration (Beta)’ failure, command < cd ‘/home/XXX/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c='eyJpZCI6Ik5WX0RPQ0tFUl9UQVJHRVRfUE9TVF9JTlNUQUxMX0NPTVAiLCJuYW1lIjoiTlZJRElBIENvbnRhaW5lciBSdW50aW1lIHdpdGggRG9ja2VyIGludGVncmF0aW9uIChCZXRhKSIsImRlc2NyaXB0aW9uIjoiTlZJRElBIENvbnRhaW5lciBSdW50aW1lIHdp…
Used sdkmanager_1.0.0-5517_amd64.deb
Would you mind to share the complete log with us for debugging?
STEP 04 → EXPORT LOGS
Why are there many deb files after I click?
I copied a part manually
14:48:01 INFO : Device Mode Host Setup in Target SDK : else
14:48:01 INFO : Device Mode Host Setup in Target SDK : echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
14:48:01 INFO : Device Mode Host Setup in Target SDK : dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o ‘[^:]*$’)
14:48:01 INFO : Device Mode Host Setup in Target SDK : for dns in $dns_list; do
14:48:01 INFO : Device Mode Host Setup in Target SDK : check_dns=$(dig @$dns nvidia.com || true)
14:48:01 INFO : Device Mode Host Setup in Target SDK : if [[ $check_dns == ‘Got answer’ ]]; then
14:48:01 INFO : Device Mode Host Setup in Target SDK : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
14:48:01 INFO : Device Mode Host Setup in Target SDK : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
14:48:01 INFO : Device Mode Host Setup in Target SDK : echo ‘Device mode on host successfuly set with DNS’ $dns’!’
14:48:01 INFO : Device Mode Host Setup in Target SDK : exit 0
14:48:01 INFO : Device Mode Host Setup in Target SDK : fi
14:48:01 INFO : Device Mode Host Setup in Target SDK : done
14:48:01 INFO : Device Mode Host Setup in Target SDK : echo ‘Can not found a valid DNS server, device mode setup failed!’
14:48:01 INFO : Device Mode Host Setup in Target SDK : echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
14:48:01 INFO : Device Mode Host Setup in Target SDK : **********************
14:48:01 INFO : Device Mode Host Setup in Target SDK : exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_TARGET_COMP.sh
14:48:01 INFO : Device Mode Host Setup in Target SDK : Found route default enp5s0, setting up device mode
14:48:01 INFO : Device Mode Host Setup in Target SDK : net.ipv4.ip_forward = 1
14:48:01 INFO : Device Mode Host Setup in Target SDK : Device mode on host successfuly set with DNS 8.8.8.8!
14:48:02 INFO : Device Mode Host Setup in Target SDK : [ Component Install Finished Successfully ]
14:48:02 INFO : Device Mode Host Setup in Target SDK : [ 16.00 KB used. Disk Avail: 800.94 GB ]
14:48:02 INFO : Device Mode Host Setup in Target SDK : [ NV_DEVICE_MODE_SETUP_TARGET_COMP Install took 0s ]
14:48:02 INFO : Device Mode Host Setup in Target SDK : command finished successfully
14:48:02 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ success
14:48:02 INFO : DateTime Target Setup : Start to install ‘DateTime Target Setup’
14:48:02 DEBUG : DateTime Target Setup : running command < cd ‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_DATETIME_SETUP_TARGET_COMP’ -v=‘1.0’ -l=‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhangjie/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘2181’ -t=‘P2888’ -e=‘/home/zhangjie/Downloads/nvidia/sdkm_downloads’ >
14:48:02 INFO : DateTime Target Setup : [ Disk Avail:800.94 GB ]
14:48:02 INFO : DateTime Target Setup : Using GenericInstaller to Install NV_DATETIME_SETUP_TARGET_COMP
14:48:02 INFO : DateTime Target Setup : change working directory to /home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888
14:48:02 INFO : DateTime Target Setup : [ Component Install Started ]
14:48:02 INFO : DateTime Target Setup : current working directory is /home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888
14:48:02 INFO : DateTime Target Setup : exec_command [host]:
14:48:02 INFO : DateTime Target Setup : **********************
14:48:02 INFO : DateTime Target Setup : #!/bin/bash
14:48:02 INFO : DateTime Target Setup : set -e
14:48:02 INFO : DateTime Target Setup : set +e
14:48:02 INFO : DateTime Target Setup : host_datetime=$(date -u)
14:48:02 INFO : DateTime Target Setup : ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “sudo date -u -s ‘$host_datetime’”
14:48:02 INFO : DateTime Target Setup : exit 0
14:48:02 INFO : DateTime Target Setup : exec_command: /tmp/tmp_NV_DATETIME_SETUP_TARGET_COMP.sh
14:48:02 INFO : DateTime Target Setup : [target] nvidia@192.168.55.1’s password:
14:48:03 INFO : DateTime Target Setup :
14:48:03 INFO : DateTime Target Setup : [target] [sudo] password for nvidia:
14:48:03 INFO : DateTime Target Setup : Wed Feb 19 06:48:02 UTC 2020
14:48:03 INFO : DateTime Target Setup : [ Component Install Finished Successfully ]
14:48:03 INFO : DateTime Target Setup : [ 20.00 KB used. Disk Avail: 800.94 GB ]
14:48:03 INFO : DateTime Target Setup : [ NV_DATETIME_SETUP_TARGET_COMP Install took 2s ]
14:48:03 INFO : DateTime Target Setup : command finished successfully
14:48:03 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ success
14:48:03 INFO : CUDA Toolkit for L4T : Start to install ‘CUDA Toolkit for L4T’
14:48:03 DEBUG : CUDA Toolkit for L4T : running command < cd ‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_CUDA_TARGET_POST_INSTALL_COMP’ -v=‘10.0’ -l=‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhangjie/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘2181’ -t=‘P2888’ -e=‘/home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb’ >
14:48:04 INFO : CUDA Toolkit for L4T : [ Disk Avail:800.94 GB ]
14:48:04 INFO : CUDA Toolkit for L4T : Using GenericInstaller to Install NV_L4T_CUDA_TARGET_POST_INSTALL_COMP
14:48:04 INFO : CUDA Toolkit for L4T : NV_L4T_CUDA_TARGET_POST_INSTALL_COMP include 1 package
14:48:04 INFO : CUDA Toolkit for L4T : [ Package Install Started ]
14:48:04 INFO : CUDA Toolkit for L4T : target deb installer start to install
14:48:04 INFO : CUDA Toolkit for L4T : exec_command: dpkg -f /home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb Package | tr -d ‘\n’
14:48:04 INFO : CUDA Toolkit for L4T : exec_command: dpkg -f /home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb Version | tr -d ‘\n’
14:48:04 INFO : CUDA Toolkit for L4T : deb file /home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb, package name [cuda-repo-l4t-10-0-local-10.0.326], package version [1.0-1]
14:48:04 INFO : CUDA Toolkit for L4T : infer package info from file name cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb [ name: cuda-repo-l4t-10-0-local-10.0.326, version: 1.0-1 ]
14:48:04 INFO : CUDA Toolkit for L4T : exec_command [target]:
14:48:04 INFO : CUDA Toolkit for L4T : **********************
14:48:04 INFO : CUDA Toolkit for L4T : #!/bin/bash
14:48:04 INFO : CUDA Toolkit for L4T : set -e
14:48:04 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:48:04 INFO : CUDA Toolkit for L4T : sudo mkdir -p /opt/nvidia/deb_repos
14:48:04 INFO : CUDA Toolkit for L4T : sudo chmod 777 /opt/nvidia/deb_repos
14:48:04 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
14:48:04 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.55.1’s password:
14:48:05 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.55.1’s password:
14:48:05 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
14:48:06 WARNING : CUDA Toolkit for L4T : Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
14:48:06 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.55.1’s password:
14:48:21 INFO : CUDA Toolkit for L4T : cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 0% 0 0.0KB/s --:-- ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 5% 50MB 50.3MB/s 00:17 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 11% 109MB 51.1MB/s 00:16 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 18% 174MB 52.6MB/s 00:14 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 25% 239MB 53.7MB/s 00:13 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 31% 298MB 54.3MB/s 00:12 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 38% 367MB 55.7MB/s 00:10 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 45% 438MB 57.3MB/s 00:09 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 53% 508MB 58.6MB/s 00:07 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 60% 579MB 59.8MB/s 00:06 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 68% 651MB 61.0MB/s 00:04 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 75% 716MB 61.4MB/s 00:03 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 82% 786MB 62.2MB/s 00:02 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 89% 855MB 62.9MB/s 00:01 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 96% 920MB 63.2MB/s 00:00 ETA cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64 100% 954MB 63.6MB/s 00:15
14:48:21 INFO : CUDA Toolkit for L4T : exec_command: dpkg -c /home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb | awk ‘{ print $6 }’ | grep ‘.pub$’ | sed ‘s/^.//’ | tr -d ‘\n’
14:48:24 INFO : CUDA Toolkit for L4T : exec_command [target]:
14:48:24 INFO : CUDA Toolkit for L4T : **********************
14:48:24 INFO : CUDA Toolkit for L4T : #!/bin/bash
14:48:24 INFO : CUDA Toolkit for L4T : set -e
14:48:24 INFO : CUDA Toolkit for L4T : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:48:24 INFO : CUDA Toolkit for L4T : function safe_apt_install {
14:48:24 INFO : CUDA Toolkit for L4T : echo “*begin $1, $2”
14:48:24 INFO : CUDA Toolkit for L4T : tmp_log=/tmp/jetpack_dpkg_log.txt
14:48:24 INFO : CUDA Toolkit for L4T : sudo rm -f $tmp_log
14:48:24 INFO : CUDA Toolkit for L4T : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:48:24 INFO : CUDA Toolkit for L4T : while [ ${CMD_STATUS} -ne 0 ]; do
14:48:24 INFO : CUDA Toolkit for L4T : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
14:48:24 INFO : CUDA Toolkit for L4T : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
14:48:24 INFO : CUDA Toolkit for L4T : else
14:48:24 INFO : CUDA Toolkit for L4T : echo “Unhandled error when running $1”; exit 1
14:48:24 INFO : CUDA Toolkit for L4T : fi
14:48:24 INFO : CUDA Toolkit for L4T : done
14:48:24 INFO : CUDA Toolkit for L4T : }
14:48:24 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb” 5
14:48:24 INFO : CUDA Toolkit for L4T : sleep 5
14:48:24 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub” 5
14:48:24 INFO : CUDA Toolkit for L4T : sleep 2
14:48:24 INFO : CUDA Toolkit for L4T : safe_apt_install “sudo apt-get -y update” 5
14:48:24 INFO : CUDA Toolkit for L4T : safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5
14:48:24 INFO : CUDA Toolkit for L4T : sudo rm -f /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
14:48:24 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.55.1’s password:
14:48:25 INFO : CUDA Toolkit for L4T : [target] nvidia@192.168.55.1’s password:
14:48:26 INFO : CUDA Toolkit for L4T :
14:48:26 INFO : CUDA Toolkit for L4T : *begin sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb, 5
14:48:26 INFO : CUDA Toolkit for L4T : [target] [sudo] password for nvidia:
14:48:32 INFO : CUDA Toolkit for L4T : Selecting previously unselected package cuda-repo-l4t-10-0-local-10.0.326.
14:48:32 INFO : CUDA Toolkit for L4T : (Reading database … 119915 files and directories currently installed.)
14:48:32 INFO : CUDA Toolkit for L4T : Preparing to unpack …/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb …
14:48:32 INFO : CUDA Toolkit for L4T : Unpacking cuda-repo-l4t-10-0-local-10.0.326 (1.0-1) …
14:48:47 INFO : CUDA Toolkit for L4T : Setting up cuda-repo-l4t-10-0-local-10.0.326 (1.0-1) …
14:48:47 INFO : CUDA Toolkit for L4T : The public CUDA GPG key does not appear to be installed.
14:48:47 INFO : CUDA Toolkit for L4T : To install the key, run this command:
14:48:47 INFO : CUDA Toolkit for L4T : sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub
14:48:52 INFO : CUDA Toolkit for L4T : *begin sudo apt-key add /var/cuda-repo-10-0-local-10.0.326/7fa2af80.pub, 5
14:48:52 INFO : CUDA Toolkit for L4T : Warning: apt-key output should not be parsed (stdout is not a terminal)
14:48:54 INFO : CUDA Toolkit for L4T : OK
14:48:55 INFO : CUDA Toolkit for L4T : *begin sudo apt-get -y update, 5
14:48:56 INFO : CUDA Toolkit for L4T : Get:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
14:48:56 INFO : CUDA Toolkit for L4T : Ign:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
14:48:56 INFO : CUDA Toolkit for L4T : Get:2 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
14:48:56 INFO : CUDA Toolkit for L4T : Get:3 file:/var/cuda-repo-10-0-local-10.0.326 Release.gpg [819 B]
14:48:56 INFO : CUDA Toolkit for L4T : Get:4 file:/var/cuda-repo-10-0-local-10.0.326 Packages [11.3 kB]
14:48:56 INFO : CUDA Toolkit for L4T : Get:5 Index of /ubuntu-ports bionic InRelease [242 kB]
14:48:58 INFO : CUDA Toolkit for L4T : Get:6 Index of /ubuntu-ports bionic-updates InRelease [88.7 kB]
14:48:58 INFO : CUDA Toolkit for L4T : Get:9 Index of /ubuntu-ports bionic-backports InRelease [74.6 kB]
14:48:58 INFO : CUDA Toolkit for L4T : Get:10 Index of /ubuntu-ports bionic-security InRelease [88.7 kB]
14:49:00 INFO : CUDA Toolkit for L4T : Get:11 Index of /ubuntu-ports bionic/main arm64 Packages [975 kB]
14:49:00 INFO : CUDA Toolkit for L4T : Get:12 Index of /ubuntu-ports bionic/main Translation-en [516 kB]
14:49:01 INFO : CUDA Toolkit for L4T : Get:13 Index of /ubuntu-ports bionic/main arm64 DEP-11 Metadata [472 kB]
14:49:01 INFO : CUDA Toolkit for L4T : Get:14 Index of /ubuntu-ports bionic/main DEP-11 48x48 Icons [118 kB]
14:49:01 INFO : CUDA Toolkit for L4T : Get:15 Index of /ubuntu-ports bionic/main DEP-11 64x64 Icons [245 kB]
14:49:01 INFO : CUDA Toolkit for L4T : Get:16 Index of /ubuntu-ports bionic/restricted arm64 Packages [664 B]
14:49:01 INFO : CUDA Toolkit for L4T : Get:17 Index of /ubuntu-ports bionic/restricted Translation-en [3,584 B]
14:49:01 INFO : CUDA Toolkit for L4T : Get:18 Index of /ubuntu-ports bionic/universe arm64 Packages [8,316 kB]
14:49:01 INFO : CUDA Toolkit for L4T : Get:7 https://repo.download.nvidia.cn/jetson/common r32 InRelease [2,541 B]
14:49:01 INFO : CUDA Toolkit for L4T : Get:8 https://repo.download.nvidia.cn/jetson/t194 r32 InRelease [2,555 B]
14:49:01 INFO : CUDA Toolkit for L4T : Get:19 https://repo.download.nvidia.cn/jetson/common r32/main arm64 Packages [13.0 kB]
14:49:02 INFO : CUDA Toolkit for L4T : Get:20 https://repo.download.nvidia.cn/jetson/t194 r32/main arm64 Packages [7,926 B]
14:49:02 INFO : CUDA Toolkit for L4T : Err:20 https://repo.download.nvidia.cn/jetson/t194 r32/main arm64 Packages
14:49:02 INFO : CUDA Toolkit for L4T : File has unexpected size (8079 != 7926). Mirror sync in progress? [IP: 123.134.184.165 443]
14:49:02 INFO : CUDA Toolkit for L4T : Hashes of expected file:
14:49:02 INFO : CUDA Toolkit for L4T : - Filesize:7926 [weak]
14:49:02 INFO : CUDA Toolkit for L4T : - SHA256:f1e623c5ca40b257530e4dfe10b1727fee5e0cf9b66906211b28709133522cda
14:49:02 INFO : CUDA Toolkit for L4T : - SHA1:79f07e7ae489457609a505a4998b54bda189ecf8 [weak]
14:49:02 INFO : CUDA Toolkit for L4T : - MD5Sum:29e7ae0e2d49248e7965842785f52b27 [weak]
14:49:02 INFO : CUDA Toolkit for L4T : Release file created at: Tue, 17 Dec 2019 23:52:40 +0000
14:49:04 INFO : CUDA Toolkit for L4T : Get:21 Index of /ubuntu-ports bionic/universe Translation-en [4,941 kB]
14:49:07 INFO : CUDA Toolkit for L4T : Get:22 Index of /ubuntu-ports bionic/universe arm64 DEP-11 Metadata [3,243 kB]
14:49:08 INFO : CUDA Toolkit for L4T : Get:23 Index of /ubuntu-ports bionic/universe DEP-11 48x48 Icons [2,151 kB]
14:49:09 INFO : CUDA Toolkit for L4T : Get:24 Index of /ubuntu-ports bionic/universe DEP-11 64x64 Icons [8,420 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:25 Index of /ubuntu-ports bionic/multiverse arm64 Packages [126 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:26 Index of /ubuntu-ports bionic/multiverse Translation-en [108 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:27 Index of /ubuntu-ports bionic/multiverse arm64 DEP-11 Metadata [44.4 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:28 Index of /ubuntu-ports bionic/multiverse DEP-11 48x48 Icons [8,931 B]
14:49:14 INFO : CUDA Toolkit for L4T : Get:29 Index of /ubuntu-ports bionic/multiverse DEP-11 64x64 Icons [225 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:30 Index of /ubuntu-ports bionic-updates/main arm64 Packages [628 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:31 Index of /ubuntu-ports bionic-updates/main Translation-en [301 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:32 Index of /ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [302 kB]
14:49:14 INFO : CUDA Toolkit for L4T : Get:33 Index of /ubuntu-ports bionic-updates/main DEP-11 48x48 Icons [73.8 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:34 Index of /ubuntu-ports bionic-updates/main DEP-11 64x64 Icons [140 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:35 Index of /ubuntu-ports bionic-updates/restricted arm64 Packages [1,064 B]
14:49:15 INFO : CUDA Toolkit for L4T : Get:36 Index of /ubuntu-ports bionic-updates/restricted Translation-en [8,440 B]
14:49:15 INFO : CUDA Toolkit for L4T : Get:37 Index of /ubuntu-ports bionic-updates/universe arm64 Packages [942 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:38 Index of /ubuntu-ports bionic-updates/universe Translation-en [326 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:39 Index of /ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [259 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:40 Index of /ubuntu-ports bionic-updates/universe DEP-11 48x48 Icons [197 kB]
14:49:15 INFO : CUDA Toolkit for L4T : Get:41 Index of /ubuntu-ports bionic-updates/universe DEP-11 64x64 Icons [449 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:42 Index of /ubuntu-ports bionic-updates/multiverse arm64 Packages [3,304 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:43 Index of /ubuntu-ports bionic-updates/multiverse Translation-en [4,576 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:44 Index of /ubuntu-ports bionic-updates/multiverse DEP-11 48x48 Icons [29 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:45 Index of /ubuntu-ports bionic-updates/multiverse DEP-11 64x64 Icons [2,638 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:46 Index of /ubuntu-ports bionic-backports/main arm64 Packages [2,512 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:47 Index of /ubuntu-ports bionic-backports/main Translation-en [1,644 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:48 Index of /ubuntu-ports bionic-backports/universe arm64 Packages [4,020 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:49 Index of /ubuntu-ports bionic-backports/universe Translation-en [1,900 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:50 Index of /ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [8,284 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:51 Index of /ubuntu-ports bionic-backports/universe DEP-11 48x48 Icons [29 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:52 Index of /ubuntu-ports bionic-backports/universe DEP-11 64x64 Icons [29 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:53 Index of /ubuntu-ports bionic-security/main arm64 Packages [426 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:54 Index of /ubuntu-ports bionic-security/main Translation-en [211 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:55 Index of /ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [32.3 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:56 Index of /ubuntu-ports bionic-security/main DEP-11 48x48 Icons [17.6 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:57 Index of /ubuntu-ports bionic-security/main DEP-11 64x64 Icons [41.5 kB]
14:49:16 INFO : CUDA Toolkit for L4T : Get:58 Index of /ubuntu-ports bionic-security/restricted arm64 Packages [668 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:59 Index of /ubuntu-ports bionic-security/restricted Translation-en [6,500 B]
14:49:16 INFO : CUDA Toolkit for L4T : Get:60 Index of /ubuntu-ports bionic-security/universe arm64 Packages [578 kB]
14:49:18 INFO : CUDA Toolkit for L4T : Get:61 Index of /ubuntu-ports bionic-security/universe Translation-en [217 kB]
14:49:18 INFO : CUDA Toolkit for L4T : Get:62 Index of /ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [37.0 kB]
14:49:18 INFO : CUDA Toolkit for L4T : Get:63 Index of /ubuntu-ports bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
14:49:18 INFO : CUDA Toolkit for L4T : Get:64 Index of /ubuntu-ports bionic-security/universe DEP-11 64x64 Icons [111 kB]
14:49:18 INFO : CUDA Toolkit for L4T : Get:65 Index of /ubuntu-ports bionic-security/multiverse arm64 Packages [1,848 B]
14:49:18 INFO : CUDA Toolkit for L4T : Get:66 Index of /ubuntu-ports bionic-security/multiverse Translation-en [2,640 B]
14:49:18 INFO : CUDA Toolkit for L4T : Get:67 Index of /ubuntu-ports bionic-security/multiverse DEP-11 48x48 Icons [29 B]
14:49:18 INFO : CUDA Toolkit for L4T : Get:68 Index of /ubuntu-ports bionic-security/multiverse DEP-11 64x64 Icons [2,638 B]
14:49:36 INFO : CUDA Toolkit for L4T : Fetched 35.8 MB in 22s (1,662 kB/s)
14:49:40 INFO : CUDA Toolkit for L4T : Reading package lists…
14:49:40 INFO : CUDA Toolkit for L4T : E: Failed to fetch https://repo.download.nvidia.cn/jetson/t194/dists/r32/main/binary-arm64/Packages.gz File has unexpected size (8079 != 7926). Mirror sync in progress? [IP: 123.134.184.165 443]
14:49:40 INFO : CUDA Toolkit for L4T : Hashes of expected file:
14:49:40 INFO : CUDA Toolkit for L4T : - Filesize:7926 [weak]
14:49:40 INFO : CUDA Toolkit for L4T : - SHA256:f1e623c5ca40b257530e4dfe10b1727fee5e0cf9b66906211b28709133522cda
14:49:40 INFO : CUDA Toolkit for L4T : - SHA1:79f07e7ae489457609a505a4998b54bda189ecf8 [weak]
14:49:40 INFO : CUDA Toolkit for L4T : - MD5Sum:29e7ae0e2d49248e7965842785f52b27 [weak]
14:49:40 INFO : CUDA Toolkit for L4T : Release file created at: Tue, 17 Dec 2019 23:52:40 +0000
14:49:40 INFO : CUDA Toolkit for L4T : E: Some index files failed to download. They have been ignored, or old ones used instead.
14:49:40 INFO : CUDA Toolkit for L4T : Unhandled error when running sudo apt-get -y update
14:49:40 INFO : CUDA Toolkit for L4T : exit status 1
14:49:40 INFO : CUDA Toolkit for L4T : [ Package Install Finished with Error ]
14:49:40 INFO : CUDA Toolkit for L4T : [ 52.00 KB used. Disk Avail: 800.94 GB ]
14:49:40 INFO : CUDA Toolkit for L4T : [ NV_L4T_CUDA_TARGET_POST_INSTALL_COMP Install took 1m36s ]
14:49:40 ERROR : CUDA Toolkit for L4T : : command safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb” 5; sleep 5; ; safe_apt_install "sudo apt-get -y install cuda-toolkit-10-0 " 5 finished with error
14:49:40 ERROR : CUDA Toolkit for L4T : command terminated with error
14:49:40 ERROR : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ failure, command < cd ‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_CUDA_TARGET_POST_INSTALL_COMP’ -v=‘10.0’ -l=‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhangjie/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘2181’ -t=‘P2888’ -e=‘/home/zhangjie/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb’ > terminated with error
14:49:42 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Start to install ‘NVIDIA Container Runtime with Docker integration (Beta)’
14:49:43 DEBUG : NVIDIA Container Runtime with Docker integration (Beta) : running command < cd ‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_DOCKER_TARGET_POST_INSTALL_COMP’ -v=‘0.9.0’ -l=‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/zhangjie/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘2181’ -t=‘P2888’ -e=‘/home/zhangjie/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_0.9.0_beta.1_arm64.deb’ >
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ Disk Avail:800.94 GB ]
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Using GenericInstaller to Install NV_DOCKER_TARGET_POST_INSTALL_COMP
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : NV_DOCKER_TARGET_POST_INSTALL_COMP include 9 package
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ Package Install Started ]
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : target deb installer start to install
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exec_command: dpkg -f /home/zhangjie/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.0.326-1_arm64.deb Package | tr -d ‘\n’
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exec_command: dpkg -f /home/zhangjie/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.0.326-1_arm64.deb Version | tr -d ‘\n’
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : deb file /home/zhangjie/Downloads/nvidia/sdkm_downloads/nvidia-container-csv-cuda_10.0.326-1_arm64.deb, package name [nvidia-container-csv-cuda], package version [10.0.326-1]
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : infer package info from file name nvidia-container-csv-cuda_10.0.326-1_arm64.deb [ name: nvidia-container-csv-cuda, version: 10.0.326-1 ]
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exec_command [target]:
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : **********************
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : #!/bin/bash
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : set -e
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sudo mkdir -p /opt/nvidia/deb_repos
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sudo chmod 777 /opt/nvidia/deb_repos
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sudo rm -f /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb
14:49:44 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] nvidia@192.168.55.1’s password:
14:49:45 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:46 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] nvidia@192.168.55.1’s password:
14:49:47 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:47 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] [sudo] password for nvidia:
14:49:48 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:48 WARNING : NVIDIA Container Runtime with Docker integration (Beta) : Warning: Permanently added ‘192.168.55.1’ (ECDSA) to the list of known hosts.
14:49:48 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] nvidia@192.168.55.1’s password:
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : nvidia-container-csv-cuda_10.0.326-1_arm64.de 0% 0 0.0KB/s --:-- ETA nvidia-container-csv-cuda_10.0.326-1_arm64.de 100% 14KB 14.5KB/s 00:00
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exec_command [target]:
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : **********************
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : #!/bin/bash
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : set -e
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : function safe_apt_install {
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : echo “*begin $1, $2”
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : tmp_log=/tmp/jetpack_dpkg_log.txt
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sudo rm -f $tmp_log
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : while [ ${CMD_STATUS} -ne 0 ]; do
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : else
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : echo “Unhandled error when running $1”; exit 1
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : fi
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : done
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : }
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb” 5
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sleep 5
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : sudo rm -f /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb
14:49:49 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] nvidia@192.168.55.1’s password:
14:49:50 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:51 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] nvidia@192.168.55.1’s password:
14:49:52 INFO : NVIDIA Container Runtime with Docker integration (Beta) :
14:49:52 INFO : NVIDIA Container Runtime with Docker integration (Beta) : *begin sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb, 5
14:49:52 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [target] [sudo] password for nvidia:
14:49:52 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Selecting previously unselected package nvidia-container-csv-cuda.
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : (Reading database … 119969 files and directories currently installed.)
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Preparing to unpack …/nvidia-container-csv-cuda_10.0.326-1_arm64.deb …
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Unpacking nvidia-container-csv-cuda (10.0.326-1) …
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dpkg: dependency problems prevent configuration of nvidia-container-csv-cuda:
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : nvidia-container-csv-cuda depends on cuda-toolkit-10-0 (= 10.0.326-1); however:
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Package cuda-toolkit-10-0 is not installed.
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dpkg: error processing package nvidia-container-csv-cuda (–install):
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : dependency problems - leaving unconfigured
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Errors were encountered while processing:
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : Unhandled error when running sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : exit status 1
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ Package Install Finished with Error ]
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ 32.00 KB used. Disk Avail: 800.94 GB ]
14:49:53 INFO : NVIDIA Container Runtime with Docker integration (Beta) : [ NV_DOCKER_TARGET_POST_INSTALL_COMP Install took 9s ]
14:49:53 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : : command safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/nvidia-container-csv-cuda_10.0.326-1_arm64.deb” 5; sleep 5; finished with error
14:49:54 ERROR : NVIDIA Container Runtime with Docker integration (Beta) : install ‘NVIDIA Container Runtime with Docker integration (Beta)’ failure, command < cd ‘/home/zhangjie/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c='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
Sorry for the late update.
It looks like the error occurs when the sdkmanager try to install CUDA:
Not sure if the server is unstable at that moment.
Could you try it again to see if everything works now?
