Description
When i used following codes to specify some layer precison to fp16, but i found all layer precision will be changed to fp16. Is there any wrong in my codes?
After build, i used inspector to print all layer and found all layer weight is Half.
logger = trt.Logger(trt.Logger.VERBOSE)
builder = trt.Builder(logger)
ctypes.CDLL(plugin_path)
trt.init_libnvinfer_plugins(logger, '')
network = builder.create_network(1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
parser = trt.OnnxParser(network, logger)
success = parser.parse_from_file(onnx_path)
for idx in range(network.num_layers):
layer = network.get_layer(idx)
if idx == 1600: # for debug
layer.precision = trt.float16
layer.set_output_type(0, trt.DataType.HALF)
config = builder.create_builder_config()
config.max_workspace_size = 4 << 30 # 4GB
config.profiling_verbosity = trt.ProfilingVerbosity.VERBOSE
config.set_flag(trt.BuilderFlag.PREFER_PRECISION_CONSTRAINTS)
config.set_flag(trt.BuilderFlag.DIRECT_IO)
config.set_flag(trt.BuilderFlag.REJECT_EMPTY_ALGORITHMS)
config.set_flag(trt.BuilderFlag.STRICT_TYPES)
config.clear_flag(trt.BuilderFlag.TF32)
config.set_flag(trt.BuilderFlag.FP16)
serialized_engine = builder.build_serialized_network(network, config)
with open(trt_path, 'wb') as f:
f.write(serialized_engine)
# Use inspector to print all layer, i found all layer weight is Half.
with open('./generator.trt', 'rb') as f:
trt_engine = trt.Runtime(trt.Logger(trt.Logger.ERROR)).deserialize_cuda_engine(f.read())
inspector = trt_engine.create_engine_inspector()
print('trt_engine layer_info:\n{}'.format(
inspector.get_engine_information(trt.LayerInformationFormat.JSON)
trt_ctx = trt_engine.create_execution_context()
Environment
TensorRT Version: TensorRT-8.6.1.6
GPU Type: NVIDIA A10
Nvidia Driver Version: 525.105.17
CUDA Version: cuda_11.8.r11.8/compiler.31833905_0
CUDNN Version: 8.7.0
Operating System + Version: Ubuntu 18.04.6 LTS
Python Version (if applicable): python3.10
TensorFlow Version (if applicable):
PyTorch Version (if applicable): torch2.0
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
