As we are productising our product, we need to stop MB1 & MB2 from printing during boot on the serial output.
Could you let us know how to do this please?
Hi jeanphilippe.arnaud,
What’s the Jetapck version in use?
Please try to configure the following lines in tegra234-mb1-bct-misc-common.dtsi and check if it could meet your requirement.
///////// Debug data //////////
debug {
uart_instance = <2>;
wdt_period_secs = <0>;
-#ifdef DISABLE_UART_MB1_MB2
log_level = <0>;
-#else
- log_level = <4>;
-#endif
uart8_usb_port_sel = <0>;
usb2_nvjtag = <0>;
Hi Kevin,
Thank you. We are using a custom board with the Orin AGX SOM. We use L4T 36.4.4.
Will try your suggestion
Hi Kevin,
I get this exception when defining DISABLE_UART_MB1_MB2
!0x200 Exception! [elr:0x5002171c, spsr:0x600002cd, esr:0x96000007, far:0x68]
Should enable_combined_uart = <1> also be changed to enable_combined_uart = <0> by any chance?
Hi Kevin,
I am still unable to reset to the log level to 0. Getting those exceptions no matter what I try,.
Any suggestion?
Please just update them as I shared(by removing those lines) instead of defining DISABLE_UART_MB1_MB2 which causes the exception issue.
