How to stream the output as RTSP stream
Hi Guys,
I wish to stream the output of deepstream application in the form of RTSP stream. I would like to interface the RTSP stream with a VMS solution to store the output.
Kindly guide me on how to do the same.
We have the implementation for ‘Encode + RTSP streaming’
https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_app_config.3.2.html%23wwpID0ENHA
Hi DaneLLL,
Thanks for the reference. I tried the same but I am not able to get good quality output when I try to retrieve from the RTSP stream. The bit rate supported is quite low. Please let me know if the same is observed at your end.
The bitrate is 4Mbps by default. Please try to set higher bitrate.
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
<b>bitrate=4000000</b>
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
