I am working with a monochrome camera on Jetson Orin NX running JetPack 5.1.4. The camera supports Y12 (12-bit grayscale) format, which I verified using v4l2-ctl:
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'Y12 ' (12-bit Greyscale)
Size: Discrete 640x480 Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 1920x1080 Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 3840x2160 Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 5120x2880 Interval: Discrete 0.017s (60.000 fps)
Size: Discrete 5120x3840 Interval: Discrete 0.017s (60.000 fps)
Currently, I am able to stream Y8 using the following GStreamer pipeline:
gst-launch-1.0 v4l2src device=/dev/video0 !
video/x-raw,format=GRAY8,width=640,height=480,framerate=60/1 !
nvvidconv !
video/x-raw,format=I420 !
fpsdisplaysink text-overlay=true video-sink=autovideosink sync=true
However, I would like to stream Y12 format from the same camera.
My questions:
Does GStreamer on Jetson Orin NX (JetPack 5.1.4) support Y12 format directly?
What is the correct GStreamer pipeline to stream Y12?
Should Y12 be treated as GRAY16_LE in GStreamer?
Does nvvidconv support Y12 / GRAY16_LE conversion?
If GStreamer does not support Y12 directly, what alternative applications or approaches can be used to stream or visualize Y12 data?
Any guidance or example pipelines would be greatly appreciated.
