How to structure multiple concurrent shuffles in the same block?
I have written a shuffle reduction function that works well for warp size 32, so I can quickly reduce arrays of size <=32. I have a need to reduce arrays of size 64. So I modified the function to call two shuffle functions. The first shuffle reduces elements 0-31 correctly, and the second shuffle is supposed to reduce elements 32-63. Instead, the second shuffle seems to add a single element to the sum 32 times. I.e if element 32 contains a 10, then the “sum” output for the second array will become 320. I have provided the full code, just call shuffleReduce() from a main function.
I am aware that shuffle functions are bound by the max warp size (32) so I made blockDim.x and blockDim.y to both be 32. I.e 32 threads in X directions is one warp, and 32 threads in Y direction is another warp. Maybe my logic is wrong, but this should allow me to do two shuffles within the same kernel at the same time, as long as the shuffles do not need to share memory.
So can anyone provide any insight as to why sumY does not appear to be calculating the sum of the row, even though sumX works perfectly? Please note nvcc provides a warning that sumY is set but never referenced…
Thanks for your time!
#include <iostream>
#include <stdio.h>
#include <stdlib.h>
__global__ void shuffleReduction(float * d_frame, float * d_colVector)
	const int SIZE = 1;
	int laneIDx = threadIdx.x%32;
	int laneIDy = threadIdx.y%32;
	const int MAX_ROW_SIZE = 64;
	float sumX[MAX_ROW_SIZE*(SIZE)];
	float sumY[MAX_ROW_SIZE*(SIZE)];
	float sum[MAX_ROW_SIZE*(SIZE)];
	sumX[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] = d_frame[laneIDx+(64*blockIdx.z)+(64*MAX_ROW_SIZE*blockIdx.y)];		//set up lanes to point to elements 0-31
	sumY[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] = d_frame[32+laneIDy+(64*blockIdx.z)+(64*MAX_ROW_SIZE*blockIdx.y)];	// set up lanes to point to elements 32-63
	__syncthreads();
	unsigned mask = 0xffffffff;
	for (int i=16; i>=1; i/=2)
		sumX[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] += __shfl_down_sync(mask, sumX[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)], i);	// this shuffle outputs correct sum
		sumY[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] += __shfl_down_sync(mask, sumY[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)], i);	// this shuffle outputs incorrect sum
	__syncthreads();
	if (threadIdx.x ==0 && blockIdx.y == 0 && blockIdx.z == 0 && threadIdx.y == 0)
		printf("sumX[0] = %f\t (correct, expected 528)\n",sumX[0]);			//this sum is correct (should be 528)
		printf("sumY[0] = %f\t (incorrect, expected 1552)\n",sumY[0]);		//this sum is incorrect (should be 2080-528 = 1552)
	//if (laneIDx==0 && laneIDy ==0)
		sum[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] = sumX[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] + sumY[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)];
	__syncthreads();
	if (threadIdx.x==0 && threadIdx.y ==0)
		d_colVector[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)] = sum[blockIdx.z+(MAX_ROW_SIZE*blockIdx.y)];
	__syncthreads();
		printf("d_colVector[0] = %f \t (incorrect, expected 2080)\n",d_colVector[0]);		//this sum should be 528+1552 = 2080
void shuffleReduce()
		const int SIZE = 1;
		float * d_frame;
		float * d_colVector;
		float h_frame[64*64*SIZE] = {};
		float h_colVector[64*SIZE] = {};
		int counter = 1;
		// fill each row with 1,2,3,4,....,64
		for (int i = 0 ; i < 64*64*(SIZE) ; i++)
			h_frame[i] = counter;
			if (counter < 64)
				counter++;
			else
				counter = 1;
		cudaMallocManaged((void**) &d_frame, 64*(SIZE)*64*sizeof(float));
		cudaMallocManaged((void**) &d_colVector, 64*(SIZE)*sizeof(float));
		memcpy(d_frame, h_frame, 64*(SIZE)*64*sizeof(float));
		//launch the kernel
		shuffleReduction<<<dim3(1,SIZE,64), dim3(32,32,1)>>>(d_frame, d_colVector);
		cudaDeviceSynchronize();
		memcpy(h_colVector, d_colVector, 64*(SIZE)*sizeof(float));
		cudaFree(d_frame);
		cudaFree(d_colVector);
That’s not how warp organization works. A 32x32 threadblock will have a “square” array of threads, totaling 1024 (32*32). If we consider this square array, the first row (of 32 threads) is a warp (where threadIdx.y is 0 for every member of that warp). The second row is another warp (where threadIdx.y is 1 for every member of that warp). And so on through 32 rows. There is no concept of a warp organized in the Y direction/dimension for a 32x32 threadblock.
A typical warp-shuffle reduction across more than 1 warp (more than 32 elements) in a threadblock would have each warp do almost the same thing. Each warp independently reduces 32 elements, producing a single result. Then deposit the warp result from each warp in shared memory, pull that data back to a single warp, and do the final reduction once again in a single warp.
You may wish to study the Block Reduce example here:
Thanks for the quick response and the link.
Thanks, seems I had a fundamental misunderstanding of how warps are structured with regards to the thread block. Using your help, I changed my laneIDx and laneIDy to be a single warp each (i.e a row)
int laneIDx, laneIDy;
	if (threadIdx.y ==0)
	else
		laneIDy = threadIdx.x%32;
I kept the rest of my code the same and it works now :) I appreciate your help Robert, especially in how fast you replied. I was not expecting help that fast.
