We want to support 10G and 1G network interface at the same time.How to modify the config ODMDATA="gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g"; in the p3701.conf.common file?
Your question is not related to your topic. 1G network is not part of UPHY so ODMDATA totally has nothing to do with it.
I get support from tech-support that I should change the ODMDATA from gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g to gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-16 if I want to support 1G network.
no, this is wrong… 1G network is not part of UPHY so totally no need to change uphy…
Only PCIe, USB3 and MGBE are related to UPHY.
What you changed is related to 10G but not related to 1G…
