I want to use an Orbbec Femto Bolt camera with isaac-ros-nvblox
, however, I did not find any documentation on how to add a new camera? Would it be possible to help me understand the procedure?
Thanks in advance!
Thanks in advance!
It seems like all that needs to be done is to make sure that the following topics are being remapped: ROS Topics and Services — isaac_ros_docs documentation.
So what I did was:
NvbloxCamera.orbbec
in /workspaces/isaac_ros-dev/src/isaac_ros_nvblox/nvblox_ros_python_utils/nvblox_ros_python_utils/nvblox_launch_utils.py
zed_example.launch.py
and change all mentions of NvbloxCamera.zedx
to NvbloxCamera.orbbec
.rviz
file for orbbec
and add it to visualization/rviz.launch.py
similar to what they have for the zed cameraperception/nvblox.launch.py
add support for orbbec
similar to what they have for the zed cameraconfig/nvblox/specializations/nvblox_orbbec.yaml
config fileAfter these files were added, we can rebuild the workspace and run the ROS 2 launch file
colcon build --event-handlers console_direct+ --cmake-args -DCMAKE_BUILD_TYPE=Release --symlink-install
source install/setup.bash
ros2 launch nvblox_examples_bringup orbbec_example.launch.py
