How to switch 10-Gb Ethernet from Tegra A to Tegra B: i2ccmd missing sources (Solved)
I am following “https://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%20DRIVE%20Linux%20SDK%20Development%20Guide%2FConfiguration%2Fnetwork_setup.html%23wwpID0E0HD0HA” in order to switch 10-Gb Ethernet from Tegra A to Tegra B. I have a custom Yocto build running based on Nvidia Vibrante Linux on Tegra-B. The move10GbePhy_B.sh script utilizes “i2ccmd” application. I need the source files for that app to compile into my Yocto build so that I can use that script file. Could you please provide the sources for that program?
Thanks,
Dear OmarAlfarouk.Alhaffar,
i2ccmd is NVIDIA authored and provides functionality that is equivalent to i2cset/i2cget.
You could use i2cset/i2cget and it is opensource. Thanks.
