I’m working on Jetson Orin and now I connect Orin with a NVME SSD.
My software version is JetPack 5.0.1
lspci -v
0005:04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Flags: bus master, fast devsel, latency 0, IRQ 54
Memory at 2b28a00000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [b0] MSI-X: Enable+ Count=33 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158] Power Budgeting <?>
Capabilities: [168] Secondary PCI Express
Capabilities: [188] Latency Tolerance Reporting
Capabilities: [190] L1 PM Substates
Kernel driver in use: nvme
How can I use DMA function to transfer data to the SSD and test the transfer/receive performance through DMA on PCIe?
Is there any example test code offered in the kernel driver? If so how to use it?
