I’ve setup the tftpserver and it is ready.
but how to use the tftpboot command with args to specify boot.img and dtb and then booting ?
Hi kassey,
Please following below steps:
- Create /etc/xinetd.d/tftp
- Create tftpboot folder:
$ mkdir /home/[username]/tftpboot - Copy boot.img and dtb file: (Please use encrypt files)
$ cp boot_sigheader.img.encrypt /home/[username]/tftpboot/boot.img
$ cp *.dtb.encrypt /home/[username]/tftpboot/jetson.dtb - Change boot-order and tftp-server ip with cbo.dts
- Flash:
$ sudo ./flash -r jetson-tx2 mmcblk0p1
- Using below command to generate the encrypt signed file:
$sudo ./flash.sh --no-flash -k kernel jetson-tx2 mmcblk0p1
$sudo ./flash.sh --no-flash -k kernel-dtb tx2 mmcblk0p1
