How to tlt-convert an ssd model trained on Tranfer Learning Toolkit
I trained a SSD model using the Transfer Learning toolkit.
I tried to deploy it on the jetson nano, however i got an error, something to do with BatchTile.
I read somewhere that i have to install tensorRT plugins on the nano and then replace my old plugin.so files.
However my tensorRT version is 5.1.6 and the latest i managed to find was 5.1.5.
Could you give me a more detailed guide on how to use the tlt-converter to deploy SSD models on deepstream.
Thank you in advance!
My Config:
Jetpack 4.2.1
Deepstream 4
TensorRT 5.1.6
Jetson Nano
Hi nooffence7100,
That’s right, you need to replace the old libnvinfer_plugin.so.
See GitHub - NVIDIA-AI-IOT/deepstream_4.x_apps: deepstream 4.x samples to deploy TLT training models for reference.
Generate the plugin in your nano board.
Please note that TensorRT OSS 5.1 branch does not support cross compilation. To compile and replace the plugin,
$ git clone -b release/5.1 https://github.com/nvidia/TensorRT  && cd  TensorRT
$ git submodule update --init --recursive && export TRT_SOURCE=`pwd`
$ cd $TRT_SOURCE
$ mkdir -p build && cd build
$ wget https://github.com/Kitware/CMake/releases/download/v3.13.5/cmake-3.13.5.tar.gz
$ tar xvf cmake-3.13.5.tar.gz
$ cd cmake-3.13.5/ && ./configure && make && sudo make install
$ cd ..
$ /usr/local/bin/cmake .. -DTRT_BIN_DIR=`pwd`/out
$ make nvinfer_plugin -j$(nproc)
## The libnvinfer_plugin.so* will be available in the `pwd`/out folder.  Then replace the system lib with the newly built lib.
$ sudo cp /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.5.x.x    /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.5.x.x.bak
$ sudo cp `pwd`/out/libnvinfer_plugin.so.5.x.x    /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.5.x.x
I did the following on a new installation of jetpack after installing deepstream:
Created TensorOSS folder in home directory
  1. git clone -b release/5.1 GitHub - NVIDIA/TensorRT: NVIDIA® TensorRT™, an SDK for high-performance deep learning inference, includes a deep learning inference optimizer and runtime that delivers low latency and high throughput for inference applications. && cd TensorRT
  2. git submodule update --init --recursive && export TRT_SOURCE=pwd
  3. cd $TRT_SOURCE
  4. mkdir -p build && cd build
  5. wget https://github.com/Kitware/CMake/releases/download/v3.13.5/cmake-3.13.5.tar.gz
  6. tar xvf cmake-3.13.5.tar.gz
  7. cd cmake-3.13.5/ && ./configure && make && sudo make install
  8. cd …
  9. /usr/local/bin/cmake … -DTRT_BIN_DIR=pwd/out
and I get this error:
ainano@ainano:~/TensorOSS/TensorRT/build$ /usr/local/bin/cmake … -DTRT_BIN_DIR=pwd/out
Building for TensorRT version: 5.1.5.0, library version: 5.1.5
CHECK for CUDA
– The CXX compiler identification is GNU 7.4.0
– The CUDA compiler identification is unknown
– Check for working CXX compiler: /usr/bin/g++
– Check for working CXX compiler: /usr/bin/g++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
CMake Error at CMakeLists.txt:47 (project):
No CMAKE_CUDA_COMPILER could be found.
Tell CMake where to find the compiler by setting either the environment
variable “CUDACXX” or the CMake cache entry CMAKE_CUDA_COMPILER to the full
path to the compiler, or to the compiler name if it is in the PATH.
– Configuring incomplete, errors occurred!
See also “/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeOutput.log”.
See also “/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeError.log”.
CMakeOutput.log:
The system is: Linux - 4.9.140-tegra - aarch64
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler: /usr/bin/g++
Build flags:
Id flags:
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
The CXX compiler identification is GNU, found in "/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/3.13.5/CompilerIdCXX/a.out"
Determining if the CXX compiler works passed with the following output:
Change Dir: /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTC_b54a3/fast"
/usr/bin/make -f CMakeFiles/cmTC_b54a3.dir/build.make CMakeFiles/cmTC_b54a3.dir/build
make[1]: Entering directory '/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp'
Building CXX object CMakeFiles/cmTC_b54a3.dir/testCXXCompiler.cxx.o
/usr/bin/g++     -o CMakeFiles/cmTC_b54a3.dir/testCXXCompiler.cxx.o -c /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTC_b54a3
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b54a3.dir/link.txt --verbose=1
/usr/bin/g++       CMakeFiles/cmTC_b54a3.dir/testCXXCompiler.cxx.o  -o cmTC_b54a3
make[1]: Leaving directory '/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp'
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_e01d2/fast"
/usr/bin/make -f CMakeFiles/cmTC_e01d2.dir/build.make CMakeFiles/cmTC_e01d2.dir/build
Building CXX object CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o
/usr/bin/g++     -o CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o -c /usr/local/share/cmake-3.13/Modules/CMakeCXXCompilerABI.cpp
Linking CXX executable cmTC_e01d2
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e01d2.dir/link.txt --verbose=1
/usr/bin/g++      -v CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o  -o cmTC_e01d2
Using built-in specs.
COLLECT_GCC=/usr/bin/g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)
COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_e01d2' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64'
 /usr/lib/gcc/aarch64-linux-gnu/7/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/7/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper -plugin-opt=-fresolution=/tmp/ccVrXkOh.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -pie -z now -z relro -o cmTC_e01d2 /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/Scrt1.o /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/7/crtbeginS.o -L/usr/lib/gcc/aarch64-linux-gnu/7 -L/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/7/../../.. CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/aarch64-linux-gnu/7/crtendS.o /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crtn.o
Parsed CXX implicit link information from above output:
  link line regex: [^( *|.*[/\])(ld|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
  ignore line: [Change Dir: /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp]
  ignore line: []
  ignore line: [Run Build Command:"/usr/bin/make" "cmTC_e01d2/fast"]
  ignore line: [/usr/bin/make -f CMakeFiles/cmTC_e01d2.dir/build.make CMakeFiles/cmTC_e01d2.dir/build]
  ignore line: [make[1]: Entering directory '/home/ainano/TensorOSS/TensorRT/build/CMakeFiles/CMakeTmp']
  ignore line: [Building CXX object CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o]
  ignore line: [/usr/bin/g++     -o CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o -c /usr/local/share/cmake-3.13/Modules/CMakeCXXCompilerABI.cpp]
  ignore line: [Linking CXX executable cmTC_e01d2]
  ignore line: [/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e01d2.dir/link.txt --verbose=1]
  ignore line: [/usr/bin/g++      -v CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o  -o cmTC_e01d2 ]
  ignore line: [Using built-in specs.]
  ignore line: [COLLECT_GCC=/usr/bin/g++]
  ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper]
  ignore line: [Target: aarch64-linux-gnu]
  ignore line: [Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1' --with-bugurl=file:///usr/share/doc/gcc-7/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-7 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu]
  ignore line: [Thread model: posix]
  ignore line: [gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1) ]
  ignore line: [COMPILER_PATH=/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/]
  ignore line: [LIBRARY_PATH=/usr/lib/gcc/aarch64-linux-gnu/7/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib/:/lib/aarch64-linux-gnu/:/lib/../lib/:/usr/lib/aarch64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/aarch64-linux-gnu/7/../../../:/lib/:/usr/lib/]
  ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'cmTC_e01d2' '-shared-libgcc' '-mlittle-endian' '-mabi=lp64']
  link line: [ /usr/lib/gcc/aarch64-linux-gnu/7/collect2 -plugin /usr/lib/gcc/aarch64-linux-gnu/7/liblto_plugin.so -plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper -plugin-opt=-fresolution=/tmp/ccVrXkOh.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --sysroot=/ --build-id --eh-frame-hdr --hash-style=gnu --as-needed -dynamic-linker /lib/ld-linux-aarch64.so.1 -X -EL -maarch64linux --fix-cortex-a53-843419 -pie -z now -z relro -o cmTC_e01d2 /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/Scrt1.o /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crti.o /usr/lib/gcc/aarch64-linux-gnu/7/crtbeginS.o -L/usr/lib/gcc/aarch64-linux-gnu/7 -L/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu -L/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib -L/lib/aarch64-linux-gnu -L/lib/../lib -L/usr/lib/aarch64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/aarch64-linux-gnu/7/../../.. CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/aarch64-linux-gnu/7/crtendS.o /usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crtn.o]
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/collect2] ==> ignore
    arg [-plugin] ==> ignore
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/liblto_plugin.so] ==> ignore
    arg [-plugin-opt=/usr/lib/gcc/aarch64-linux-gnu/7/lto-wrapper] ==> ignore
    arg [-plugin-opt=-fresolution=/tmp/ccVrXkOh.res] ==> ignore
    arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
    arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
    arg [-plugin-opt=-pass-through=-lc] ==> ignore
    arg [--sysroot=/] ==> ignore
    arg [--build-id] ==> ignore
    arg [--eh-frame-hdr] ==> ignore
    arg [--hash-style=gnu] ==> ignore
    arg [--as-needed] ==> ignore
    arg [-dynamic-linker] ==> ignore
    arg [/lib/ld-linux-aarch64.so.1] ==> ignore
    arg [-X] ==> ignore
    arg [-EL] ==> ignore
    arg [-maarch64linux] ==> ignore
    arg [--fix-cortex-a53-843419] ==> ignore
    arg [-pie] ==> ignore
    arg [-znow] ==> ignore
    arg [-zrelro] ==> ignore
    arg [-o] ==> ignore
    arg [cmTC_e01d2] ==> ignore
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/Scrt1.o] ==> ignore
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crti.o] ==> ignore
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/crtbeginS.o] ==> ignore
    arg [-L/usr/lib/gcc/aarch64-linux-gnu/7] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/7]
    arg [-L/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu]
    arg [-L/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib]
    arg [-L/lib/aarch64-linux-gnu] ==> dir [/lib/aarch64-linux-gnu]
    arg [-L/lib/../lib] ==> dir [/lib/../lib]
    arg [-L/usr/lib/aarch64-linux-gnu] ==> dir [/usr/lib/aarch64-linux-gnu]
    arg [-L/usr/lib/../lib] ==> dir [/usr/lib/../lib]
    arg [-L/usr/lib/gcc/aarch64-linux-gnu/7/../../..] ==> dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../..]
    arg [CMakeFiles/cmTC_e01d2.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
    arg [-lstdc++] ==> lib [stdc++]
    arg [-lm] ==> lib [m]
    arg [-lgcc_s] ==> lib [gcc_s]
    arg [-lgcc] ==> lib [gcc]
    arg [-lc] ==> lib [c]
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/crtendS.o] ==> ignore
    arg [/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu/crtn.o] ==> ignore
  collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/7] ==> [/usr/lib/gcc/aarch64-linux-gnu/7]
  collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../../aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
  collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../../../lib] ==> [/usr/lib]
  collapse library dir [/lib/aarch64-linux-gnu] ==> [/lib/aarch64-linux-gnu]
  collapse library dir [/lib/../lib] ==> [/lib]
  collapse library dir [/usr/lib/aarch64-linux-gnu] ==> [/usr/lib/aarch64-linux-gnu]
  collapse library dir [/usr/lib/../lib] ==> [/usr/lib]
  collapse library dir [/usr/lib/gcc/aarch64-linux-gnu/7/../../..] ==> [/usr/lib]
  implicit libs: [stdc++;m;gcc_s;gcc;c;gcc_s;gcc]
  implicit dirs: [/usr/lib/gcc/aarch64-linux-gnu/7;/usr/lib/aarch64-linux-gnu;/usr/lib;/lib/aarch64-linux-gnu;/lib]
  implicit fwks: []
Detecting CXX [-std=c++1z] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_fb1b2/fast"
/usr/bin/make -f CMakeFiles/cmTC_fb1b2.dir/build.make CMakeFiles/cmTC_fb1b2.dir/build
Building CXX object CMakeFiles/cmTC_fb1b2.dir/feature_tests.cxx.o
/usr/bin/g++    -std=c++1z -o CMakeFiles/cmTC_fb1b2.dir/feature_tests.cxx.o -c /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_fb1b2
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_fb1b2.dir/link.txt --verbose=1
/usr/bin/g++       CMakeFiles/cmTC_fb1b2.dir/feature_tests.cxx.o  -o cmTC_fb1b2
    Feature record: CXX_FEATURE:1cxx_aggregate_default_initializers
    Feature record: CXX_FEATURE:1cxx_alias_templates
    Feature record: CXX_FEATURE:1cxx_alignas
    Feature record: CXX_FEATURE:1cxx_alignof
    Feature record: CXX_FEATURE:1cxx_attributes
    Feature record: CXX_FEATURE:1cxx_attribute_deprecated
    Feature record: CXX_FEATURE:1cxx_auto_type
    Feature record: CXX_FEATURE:1cxx_binary_literals
    Feature record: CXX_FEATURE:1cxx_constexpr
    Feature record: CXX_FEATURE:1cxx_contextual_conversions
    Feature record: CXX_FEATURE:1cxx_decltype
    Feature record: CXX_FEATURE:1cxx_decltype_auto
    Feature record: CXX_FEATURE:1cxx_decltype_incomplete_return_types
    Feature record: CXX_FEATURE:1cxx_default_function_template_args
    Feature record: CXX_FEATURE:1cxx_defaulted_functions
    Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers
    Feature record: CXX_FEATURE:1cxx_delegating_constructors
    Feature record: CXX_FEATURE:1cxx_deleted_functions
    Feature record: CXX_FEATURE:1cxx_digit_separators
    Feature record: CXX_FEATURE:1cxx_enum_forward_declarations
    Feature record: CXX_FEATURE:1cxx_explicit_conversions
    Feature record: CXX_FEATURE:1cxx_extended_friend_declarations
    Feature record: CXX_FEATURE:1cxx_extern_templates
    Feature record: CXX_FEATURE:1cxx_final
    Feature record: CXX_FEATURE:1cxx_func_identifier
    Feature record: CXX_FEATURE:1cxx_generalized_initializers
    Feature record: CXX_FEATURE:1cxx_generic_lambdas
    Feature record: CXX_FEATURE:1cxx_inheriting_constructors
    Feature record: CXX_FEATURE:1cxx_inline_namespaces
    Feature record: CXX_FEATURE:1cxx_lambdas
    Feature record: CXX_FEATURE:1cxx_lambda_init_captures
    Feature record: CXX_FEATURE:1cxx_local_type_template_args
    Feature record: CXX_FEATURE:1cxx_long_long_type
    Feature record: CXX_FEATURE:1cxx_noexcept
    Feature record: CXX_FEATURE:1cxx_nonstatic_member_init
    Feature record: CXX_FEATURE:1cxx_nullptr
    Feature record: CXX_FEATURE:1cxx_override
    Feature record: CXX_FEATURE:1cxx_range_for
    Feature record: CXX_FEATURE:1cxx_raw_string_literals
    Feature record: CXX_FEATURE:1cxx_reference_qualified_functions
    Feature record: CXX_FEATURE:1cxx_relaxed_constexpr
    Feature record: CXX_FEATURE:1cxx_return_type_deduction
    Feature record: CXX_FEATURE:1cxx_right_angle_brackets
    Feature record: CXX_FEATURE:1cxx_rvalue_references
    Feature record: CXX_FEATURE:1cxx_sizeof_member
    Feature record: CXX_FEATURE:1cxx_static_assert
    Feature record: CXX_FEATURE:1cxx_strong_enums
    Feature record: CXX_FEATURE:1cxx_template_template_parameters
    Feature record: CXX_FEATURE:1cxx_thread_local
    Feature record: CXX_FEATURE:1cxx_trailing_return_types
    Feature record: CXX_FEATURE:1cxx_unicode_literals
    Feature record: CXX_FEATURE:1cxx_uniform_initialization
    Feature record: CXX_FEATURE:1cxx_unrestricted_unions
    Feature record: CXX_FEATURE:1cxx_user_literals
    Feature record: CXX_FEATURE:1cxx_variable_templates
    Feature record: CXX_FEATURE:1cxx_variadic_macros
    Feature record: CXX_FEATURE:1cxx_variadic_templates
Detecting CXX [-std=c++14] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_97489/fast"
/usr/bin/make -f CMakeFiles/cmTC_97489.dir/build.make CMakeFiles/cmTC_97489.dir/build
Building CXX object CMakeFiles/cmTC_97489.dir/feature_tests.cxx.o
/usr/bin/g++    -std=c++14 -o CMakeFiles/cmTC_97489.dir/feature_tests.cxx.o -c /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_97489
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_97489.dir/link.txt --verbose=1
/usr/bin/g++       CMakeFiles/cmTC_97489.dir/feature_tests.cxx.o  -o cmTC_97489
Detecting CXX [-std=c++11] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_dc668/fast"
/usr/bin/make -f CMakeFiles/cmTC_dc668.dir/build.make CMakeFiles/cmTC_dc668.dir/build
Building CXX object CMakeFiles/cmTC_dc668.dir/feature_tests.cxx.o
/usr/bin/g++    -std=c++11 -o CMakeFiles/cmTC_dc668.dir/feature_tests.cxx.o -c /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_dc668
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_dc668.dir/link.txt --verbose=1
/usr/bin/g++       CMakeFiles/cmTC_dc668.dir/feature_tests.cxx.o  -o cmTC_dc668
    Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers
    Feature record: CXX_FEATURE:0cxx_attribute_deprecated
    Feature record: CXX_FEATURE:0cxx_binary_literals
    Feature record: CXX_FEATURE:0cxx_contextual_conversions
    Feature record: CXX_FEATURE:0cxx_decltype_auto
    Feature record: CXX_FEATURE:0cxx_digit_separators
    Feature record: CXX_FEATURE:0cxx_generic_lambdas
    Feature record: CXX_FEATURE:0cxx_lambda_init_captures
    Feature record: CXX_FEATURE:0cxx_relaxed_constexpr
    Feature record: CXX_FEATURE:0cxx_return_type_deduction
    Feature record: CXX_FEATURE:0cxx_variable_templates
Detecting CXX [-std=c++98] compiler features compiled with the following output:
Run Build Command:"/usr/bin/make" "cmTC_39d24/fast"
/usr/bin/make -f CMakeFiles/cmTC_39d24.dir/build.make CMakeFiles/cmTC_39d24.dir/build
Building CXX object CMakeFiles/cmTC_39d24.dir/feature_tests.cxx.o
/usr/bin/g++    -std=c++98 -o CMakeFiles/cmTC_39d24.dir/feature_tests.cxx.o -c /home/ainano/TensorOSS/TensorRT/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_39d24
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/cmTC_39d24.dir/link.txt --verbose=1
/usr/bin/g++       CMakeFiles/cmTC_39d24.dir/feature_tests.cxx.o  -o cmTC_39d24
    Feature record: CXX_FEATURE:0cxx_alias_templates
    Feature record: CXX_FEATURE:0cxx_alignas
    Feature record: CXX_FEATURE:0cxx_alignof
    Feature record: CXX_FEATURE:0cxx_attributes
    Feature record: CXX_FEATURE:0cxx_auto_type
    Feature record: CXX_FEATURE:0cxx_constexpr
    Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types
    Feature record: CXX_FEATURE:0cxx_default_function_template_args
    Feature record: CXX_FEATURE:0cxx_defaulted_functions
    Feature record: CXX_FEATURE:0cxx_defaulted_move_initializers
    Feature record: CXX_FEATURE:0cxx_delegating_constructors
    Feature record: CXX_FEATURE:0cxx_deleted_functions
    Feature record: CXX_FEATURE:0cxx_enum_forward_declarations
    Feature record: CXX_FEATURE:0cxx_explicit_conversions
    Feature record: CXX_FEATURE:0cxx_extended_friend_declarations
    Feature record: CXX_FEATURE:0cxx_extern_templates
    Feature record: CXX_FEATURE:0cxx_final
    Feature record: CXX_FEATURE:0cxx_func_identifier
    Feature record: CXX_FEATURE:0cxx_generalized_initializers
    Feature record: CXX_FEATURE:0cxx_inheriting_constructors
    Feature record: CXX_FEATURE:0cxx_inline_namespaces
    Feature record: CXX_FEATURE:0cxx_lambdas
    Feature record: CXX_FEATURE:0cxx_local_type_template_args
    Feature record: CXX_FEATURE:0cxx_long_long_type
    Feature record: CXX_FEATURE:0cxx_noexcept
    Feature record: CXX_FEATURE:0cxx_nonstatic_member_init
    Feature record: CXX_FEATURE:0cxx_nullptr
    Feature record: CXX_FEATURE:0cxx_override
    Feature record: CXX_FEATURE:0cxx_range_for
    Feature record: CXX_FEATURE:0cxx_raw_string_literals
    Feature record: CXX_FEATURE:0cxx_reference_qualified_functions
    Feature record: CXX_FEATURE:0cxx_right_angle_brackets
    Feature record: CXX_FEATURE:0cxx_rvalue_references
    Feature record: CXX_FEATURE:0cxx_sizeof_member
    Feature record: CXX_FEATURE:0cxx_static_assert
    Feature record: CXX_FEATURE:0cxx_strong_enums
    Feature record: CXX_FEATURE:0cxx_thread_local
    Feature record: CXX_FEATURE:0cxx_trailing_return_types
    Feature record: CXX_FEATURE:0cxx_unicode_literals
    Feature record: CXX_FEATURE:0cxx_uniform_initialization
    Feature record: CXX_FEATURE:0cxx_unrestricted_unions
    Feature record: CXX_FEATURE:0cxx_user_literals
    Feature record: CXX_FEATURE:0cxx_variadic_macros
    Feature record: CXX_FEATURE:0cxx_variadic_templates
CMakeError.log:
Compiling the CUDA compiler identification source file "CMakeCUDACompilerId.cu" failed.
Compiler: CMAKE_CUDA_COMPILER-NOTFOUND
Build flags:
Id flags:  -v;--keep;--keep-dir;tmp
The output was:
No such file or directory
Build flags:
The output was:
I was able to overcome this problem by changing:
//CUDA compiler
CMAKE_CUDA_COMPILER:FILEPATH=/usr/local/cuda-10.0/bin/nvcc
in $TRT_SOURCE/build/CMakeCache.txt
This is the output from issuing the command now:
~/TensorOSS/TensorRT/build$ /usr/local/bin/cmake .. -DTRT_BIN_DIR=`pwd`/out
CHECK for CUDA
-- The CUDA compiler identification is NVIDIA 10.0.326
-- Check for working CUDA compiler: /usr/local/cuda-10.0/bin/nvcc
-- Check for working CUDA compiler: /usr/local/cuda-10.0/bin/nvcc -- works
-- Detecting CUDA compiler ABI info
-- Detecting CUDA compiler ABI info - done
-- Targeting TRT Platform: x86_64
-- CUDA version set to 10.1
-- cuDNN version set to 7.5
-- Protobuf version set to 3.0.0
-- Looking for C++ include pthread.h
-- Looking for C++ include pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for one of the modules 'zlib'
-- Found CUDA: /usr/local/cuda (found suitable version "10.1", minimum required is "10.1")
-- Using libprotobuf /home/ainano/TensorOSS/TensorRT/build/third_party.protobuf/lib/libprotobuf.a
-- ========================= Importing and creating target nvinfer ==========================
-- Looking for library nvinfer
-- Library that was found /usr/lib/aarch64-linux-gnu/libnvinfer.so
-- ========================= Importing and creating target nvuffparser ==========================
-- Looking for library nvparsers
-- Library that was found /usr/lib/aarch64-linux-gnu/libnvparsers.so
-- Protobuf proto/trtcaffe.proto -> proto/trtcaffe.pb.cc proto/trtcaffe.pb.h
-- /home/ainano/TensorOSS/TensorRT/build/parsers/caffe
-- The C compiler identification is GNU 7.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Build type not set - defaulting to Release
-- ******** Summary ********
--   CMake version         : 3.13.5
--   CMake command         : /usr/local/bin/cmake
--   System                : Linux
--   C++ compiler          : /usr/bin/g++
--   C++ compiler version  : 7.4.0
--   CXX flags             : -Wno-deprecated-declarations  -DBUILD_SYSTEM=cmake_oss -Wall -Wnon-virtual-dtor
--   Build type            : Release
--   Compile definitions   : _PROTOBUF_INSTALL_DIR=/home/ainano/TensorOSS/TensorRT/build/third_party.protobuf;ONNX_NAMESPACE=onnx2trt_onnx
--   CMAKE_PREFIX_PATH     :
--   CMAKE_INSTALL_PREFIX  : /usr/local
--   CMAKE_MODULE_PATH     :
--   ONNX version          : 1.3.0
--   ONNX NAMESPACE        : onnx2trt_onnx
--   ONNX_BUILD_TESTS      : OFF
--   ONNX_BUILD_BENCHMARKS : OFF
--   ONNX_USE_LITE_PROTO   : OFF
--   ONNXIFI_DUMMY_BACKEND : OFF
--   Protobuf compiler     :
--   Protobuf includes     :
--   Protobuf libraries    :
--   BUILD_ONNX_PYTHON     : OFF
-- GPU_ARCH is not defined. Generating CUDA code for default SMs.
-- Found CUDNN: /usr/include
-- Found TensorRT headers at /home/ainano/TensorOSS/TensorRT/include
-- Find TensorRT libs at /usr/lib/aarch64-linux-gnu/libnvinfer.so;/usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so
-- Found TENSORRT: /home/ainano/TensorOSS/TensorRT/include
-- Adding new sample: sample_char_rnn
--     - Parsers Used: none
--     - InferPlugin Used: OFF
--     - Licensing: opensource
-- Adding new sample: sample_fasterRCNN
--     - Parsers Used: caffe
--     - InferPlugin Used: ON
-- Adding new sample: sample_googlenet
-- Adding new sample: sample_int8
-- Adding new sample: sample_int8_api
--     - Parsers Used: onnx
-- Adding new sample: sample_mlp
-- Adding new sample: sample_mnist
-- Adding new sample: sample_mnist_api
-- Adding new sample: sample_movielens
--     - Parsers Used: uff
-- Adding new sample: sample_onnx_mnist
-- Adding new sample: sample_plugin
-- Adding new sample: sample_ssd
-- Adding new sample: sample_uff_mnist
-- Adding new sample: sample_uff_ssd
-- Adding new sample: trtexec
--     - Parsers Used: caffe;uff;onnx
-- Configuring done
-- Generating done
-- Build files have been written to: /home/ainano/TensorOSS/TensorRT/build
