• Hardware (T4/V100/Xavier/Nano/etc) : A100 DGX
I am trying to train speech to text conformer model on custom dataset using tao toolkit. This training doc I used for reference.
I have installed docker image for it and create container using following commands -
sudo docker pull nvcr.io/nvidia/tao/tao-toolkit:4.0.0-pyt
sudo docker run -it --rm --gpus all -v /mnt/:/workspace/ nvcr.io/nvidia/tao/tao-toolkit:4.0.0-pyt
This created container successfully but tao command not working. Here are the logs-
=== TAO Toolkit PyTorch ===NVIDIA Release 4.0.0-PyTorch (build 44447543)
TAO Toolkit Version 4.0.0Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the TAO Toolkit End User License Agreement.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/tao-toolkit-software-license-agreementNOTE: CUDA Forward Compatibility mode ENABLED.
Using CUDA 11.8 driver version 520.54 with kernel driver version 450.191.01.
See CUDA Compatibility :: NVIDIA Data Center GPU Driver Documentation for details.root@56b7919e7a58:/opt/nvidia/tools# tao --help
bash: tao: command not found
Please correct the process if I am doing it wrong and let me know the correct way to doing same task on remote server.
