How to transmit 2 different camera images at the same time
Software Version
[*] DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.7.1.8928
[*] other
Host Machine Version
[*] native Ubuntu 18.04
other
Hi Nvidia,
I am working on the nvstream samples, now I want to transmit the 2 different camera
images at the same time via the nvscistream channel.
As we know, the different camera have different sync and buf attributes, but in the multicast sample,
it only send 1 sync attribute to the opposite endpoint at the beginning, hence I can only transmit 1 type image by this channel,
am I right?
so how can I send 2 types camera data via the nvscistream_0 at the same time ?
Regards,
Dear @user110377,
Are you asking you want to transfer two different camera data using a single nvscistream?
Yes, But I can’t find a good solution for now. may something I still not understand.
Dear @user110377,
Each camera will have seperate producer and One NvScistream can not have two producers.
Thanks for your reply.
So if I have two cameras(front and rear), and two consumers, then I need to setup two producers and also four nvscistreams for these two consumers.
nvscistream_1 and nvscistream_3 for producer 1
nvscistream_5 and nvscistream_7 for producer 2
Am I right?
Dear @user110377,
May I know your use case? Do each camera has to send data to 2 consumers or just its corresponding consumer?
Hi
I want to know both of them, could you please explain how to implement those two use cases you mentioned?
Regards,
Dear @user110377,
For one consumer for each producer, please check https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/Graphics/nvsci_nvscistream_sample_app.html#wwpID0E0GC0HA
For multiple consumers for each producer, please check https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/Graphics/nvsci_nvscistream_sample_app.html#wwpID0E6HA
Hi
Thanks for your reply, actually I already read and finished the exercise in the link you give.
Let me make a short.
I have two cameras, and I want to multicast them to two different consumers, so I need to create two producers and bind them to the corresponding endpoints.
Each consumer who want to receive the two producers, it should bind itself to two endpoint at the same time.
For example.
producer1 → nvscistream_0 nvscistream_2,
producer2 → nvscistream_4 nvscistream_6,
consumer ← nvscistream_1 to receive the producer1
consumer ← nvscistream_5 to receive the producer2
if I want to use more endpoint, I need to modify the configuration file in /etc/
Am I right?
Regards
Hello
I think this is very inefficient, if I have ten cameras and distribute to four consumers, then I will consume forty streams.
Dear @user110377,
The entries in nvsciipc.cfg tells just IPC endpoint names and not the NvStreams.
The producer can use two IPC endpoints( like nvscistream_0 nvscistream_2) similar to NvSciStream multi cast sample. The two consumer processes can use its corresponding IPC endpoints(nvscistream_1 and nvscistream_3) from nvsciipc.cfg
You need to use multicast block for each camera. In the upstream end one camera producer block is connected and in downstream end every consumer is connected separately to multicast block.
Hi, thanks,
