How to trigger SMS / Notification on Mobile device from Deepstream pipeline?
• Hardware Platform (Jetson / GPU) - GPU
• DeepStream Version :- 5
In deepstream test 5 app, e.g If people count is more than 10, then I want to trigger SMS or Notification on Mobile devices. Do we have such provision in deepstream pipeline ? If yes please suggest approach.
There are plugin that support device to cloud messaging, as described in IoT — DeepStream 6.1.1 Release documentation. However the notification to mobile device or SMS is not part of DeepStream, it is the scope of app/cloud application development.
Hi @yingliu ,
We are already using Cloud messaging but we want to use notification at edge device within pipeline itself. Please suggest on this approach.
Could add a probe to deepstream, and check the meta data for your counts. From there you could trigger an sms via your cellular modem in the probe function. Alternatively pass the counts to a separate process running on cpu so you don’t hold up the probe function. This process can be use to trigger the sms.
You can get the count in the DS. You should implement tiigger SMS in your application.
