How to turn off fan after ./jetson_clocks.sh?
When running program I turn on my fan to accelerate calculation by using jetson_clocks.sh.
And now I would like to turn it off to let it have a rest,does anyone know how to do?
I think this file is what you are interested in:
/sys/kernel/debug/tegra_fan/target_pwm
On a default boot it uses “0”. Maximizing would be:
sudo echo 255 > /sys/kernel/debug/tegra_fan/target_pwm
Try:
sudo echo 0 > /sys/kernel/debug/tegra_fan/target_pwm
Note that if the fan is needed it will still be used, so it may take time for the fan to slow if previous operation has built up heat.
You can also save a clock config (for example just after boot with slow clocks) with:
sudo /home/nvidia/jetson_clocks.sh --store
The clocks config will be stored in your home directory into file l4t_dfs.conf.
Then, if you’ve boosted the clocks and want to restore the slow clocks mode saved into that file, you would just launch:
sudo /home/nvidia/jetson_clocks.sh --restore
What if I haven’t stored --store jetson_clock and want to restore?
Reboot, and it goes back to default. Run the --store. Then run the regular jetson_clocks.sh and the --restore will work.
