Wondering if there’s any documentation on how to upgrade JetPack’s 3.2 CuDNN 7.0 to a higher version. I’m faced with the following error below and assume one remedy is to update CuDNN to a higher version, that my code/model was originally compiled on. I downloaded “cuDNN v7.3.1 Runtime Library for Ubuntu16.04 (Deb)” from https://developer.nvidia.com/rdp/cudnn-download, but later read on a discussion forum that TensorRT 3.0 GA doesn’t support any CuDNN versions other than the packaged 7.0 in JetPack 3.2. I spent a long time setting up a variety of packages on the Jetson, hesitant to reflash to 3.3 and thereby wipe out the total image. Welcome thoughts - thanks for your feedback.
2018-10-21 17:05:51.219853: E tensorflow/stream_executor/cuda/cuda_dnn.cc:324] Loaded runtime CuDNN library: 7.0.5 but source was compiled with: 7.1.5. CuDNN library major and minor version needs to match or have higher minor version in case of CuDNN 7.0 or later version. If using a binary install, upgrade your CuDNN library. If building from sources, make sure the library loaded at runtime is compatible with the version specified during compile configuration.
