How to upgrade tensorrt
I want to upgrade tensorrt to 8.6.1 such that it supports bool instead of np.bool because np.bool was deprecated. But if I use
pip install tensorrt --upgrade
The error occurs:
ERROR: Could not build wheels for tensorrt, which is required to install pyproject.toml-based projects
If I want to upgrade it via sudo apt upgrade tensorrt, it shows tensorrt is already the newest version (8.5.2.2-1+cuda11.4)..
So how to upgrade tensorrt to 8.6.1 in order to support bool? Besides, I don’t want to use the container.
Environment:
cuda: 11.4
Jetpack: 5.1.3
python: 3.8
Present Tensorrt version: 8.5.2.2
System: Ubuntu 20.04
If you are using Orin module, I would like to suggest you to go with jetpack 6.0. Here you can freely install different versions of CUDA, cuDNN and TensorRT too.
