How to use 4 USB webcam with NVIDIA Jetson TX2 Developer kit using USB hub?
I am trying to use 4 USB webcams with NVIDIA jetson TX2 developer kit but I am unable to get the output, the program shows the following error:
VIDIOC_QUERYCTRL: Input/output error
VIDIOC_STREAMON: No space left on device
File “multiCameraProcessing.py”, line 73, in
CaptureImages()
File “multiCameraProcessing.py”, line 70, in init
self.processImages()
File “multiCameraProcessing.py”, line 51, in processImages
frame3_undistort = self.undistort.image_undistort(frame3, camera_name_right)
File “/home/nvidia/Desktop/Thesis/Programs_v3/Undistortion.py”, line 25, in image_undistort
dim1 = image.shape[:2][::-1]
AttributeError: ‘NoneType’ object has no attribute ‘shape’
Currently I am using two USb hubs 3.o connected with the USB 3.0 and 2.0 hub port in Jetson TX2 but I am only able to access two cameras together, as soon as i request for the frame of 3rd camera is shows the above error.
Can I think of using this cameras using POE(Power over ethernet), is that possible?
Please suggest a solution on how to use 4 USB webcams together
We suggest you try PCIe-USB hub such as
https://devtalk.nvidia.com/default/topic/1027100
