• Hardware Platform (Jetson / GPU):Jetson
• DeepStream Version : 6.0.1
• JetPack Version (valid for Jetson only): 4.6.1
• TensorRT Version:8.2.1
• Issue Type( questions, new requirements, bugs): question
I want to use NvDsEventMsgMeta to create a message with my own variables in extMsg.
sample assigns “NvDsVehicleObject” and “NvDsPersonObject” to extMsg as follows.
def generate_event_msg_meta(data, class_id):
meta =pyds.NvDsEventMsgMeta.cast(data)
meta.sensorId = 0
meta.placeId = 0
meta.moduleId = 0
meta.sensorStr = "sensor-0"
meta.ts = pyds.alloc_buffer(MAX_TIME_STAMP_LEN + 1)
pyds.generate_ts_rfc3339(meta.ts, MAX_TIME_STAMP_LEN) #Generate timestamp
# This demonstrates how to attach custom objects.
# Any custom object as per requirement can be generated and attached
# like NvDsVehicleObject / NvDsPersonObject. Then that object should
# be handled in payload generator library (nvmsgconv.cpp) accordingly.
if(class_id==PGIE_CLASS_ID_VEHICLE):
meta.type = pyds.NvDsEventType.NVDS_EVENT_MOVING
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE
meta.objClassId = PGIE_CLASS_ID_VEHICLE
obj = pyds.alloc_nvds_vehicle_object()
obj = generate_vehicle_meta(obj) #See NvDsVehicleObject example code
meta.extMsg = obj
meta.extMsgSize = sys.getsizeof(pyds.NvDsVehicleObject);
if(class_id == PGIE_CLASS_ID_PERSON):
meta.type =pyds.NvDsEventType.NVDS_EVENT_ENTRY
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON;
meta.objClassId = PGIE_CLASS_ID_PERSON
obj = pyds.alloc_nvds_person_object()
obj=generate_person_meta(obj)
meta.extMsg = obj
meta.extMsgSize = sys.getsizeof(pyds.NvDsPersonObject)
return meta
I would like to assign the following content instead of “NvDsVehicleObject” or “NvDsPersonObject” for example.
Do you have a sample?
class MyData:
name = 'test' # type :str
probability = 0.15 # type :float
name_exists = Ture #type :bool
#and more …
