How to use CAN protocol wake pin on TX2?
I am using Jetson TX2. I want to use CAN1 and CAN2 protocol on TX2. Will only the TX and RX pins of CAN1 and CAN2 pins be enough?
Should I use the CAN_WAKE pin for CAN communication? If I’m going to use it, I have to pull high for communication. Do you need a pull-up resistor?
Please find more info from NVIDIA Jetson Linux Driver Package Software Features : Hardware Setup | NVIDIA Docs
