Hello, i wonder how to use clara_pt_brain_mri_segmentation, this model? There is no AIAA config file in the config folder. So it can not be loaded in AIAA? If I want to see the visualized result of segmentation, how can I do realize it? Without AIAA, 3d slicer or OHIF can not work correctly. Thank you for the reply.
Hi
The reason this MMAR doesn’t have a AIAA.conf is it is a multi-channel model as you need T1, T2, T1c and FLAIR. It is not supported by slicer plugin yet.
please use the single channel MMAR clara_pt_brain_mri_segmentation_t1c | NVIDIA NGC
