Hi, nvidia teams:
I want to add “alc5640” codec’s support on devkit, I add the following code in device tree:
+#include <audio/tegra-platforms-audio-dai-links.dtsi>
+#include <audio/tegra186-audio-dai-links.dtsi>
+#include <dt-bindings/sound/rt5640.h>
i2c@31e0000 {*
+ rt5640: rt5640.8-001c@1c {
+ compatible = “realtek,rt5640”;
+ reg = <0x1c>;
+ clocks = <&bpmp TEGRA234_CLK_AUD_MCLK>;
+ clock-names = “mclk”;
+ realtek,dmic1-data-pin = <RT5640_DMIC1_DATA_PIN_NONE>;
+ realtek,dmic2-data-pin = <RT5640_DMIC2_DATA_PIN_NONE>;
+ realtek,jack-detect-source = <RT5640_JD_SRC_JD2_IN4N>;
+ interrupt-parent = <&tegra_main_gpio>;
+ interrupts = <TEGRA234_MAIN_GPIO(J, 2) GPIO_ACTIVE_HIGH>;
+ #sound-dai-cells = <1>;
+ sound-name-prefix = “CVB-RT”;
+ status = “okay”;
+ tegra_sound: sound {
+ compatible = “nvidia,tegra186-ape”;
+ clocks = <&bpmp_clks TEGRA234_CLK_PLLA>,
+ <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>,
+ <&bpmp_clks TEGRA234_CLK_AUD_MCLK>;
+ clock-names = “pll_a”, “pll_a_out0”, “extern1”;
+ assigned-clocks = <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>,
+ assigned-clock-parents = <&bpmp_clks TEGRA234_CLK_PLLA>,
+ <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>;
+ nvidia-audio-card,widgets =
+ “Headphone”, “CVB-RT Headphone Jack”,
+ “Microphone”, “CVB-RT Mic Jack”,
+ “Speaker”, “CVB-RT Int Spk”,
+ “Microphone”, “CVB-RT Int Mic”;
+ nvidia-audio-card,routing =
+ “CVB-RT Headphone Jack”, “CVB-RT HPOL”,
+ “CVB-RT Headphone Jack”, “CVB-RT HPOR”,
+ “CVB-RT IN1P”, “CVB-RT Mic Jack”,
+ “CVB-RT IN2P”, “CVB-RT Mic Jack”,
+ “CVB-RT Int Spk”, “CVB-RT SPOLP”,
+ “CVB-RT Int Spk”, “CVB-RT SPORP”,
+ “CVB-RT DMIC1”, “CVB-RT Int Mic”,
+ “CVB-RT DMIC2”, “CVB-RT Int Mic”;
+ nvidia-audio-card,mclk-fs = <256>;
+&i2s1_to_codec {
+ link-name = “rt5640-playback”;
+ codec {
+ sound-dai = <&rt5640 0>;
+ prefix = “CVB-RT”;
but when I use “aplay” command to play .wav file, it only play noise. and print an error log:
"[ 86.188104] rt5640 8-001c: ASoC: error at snd_soc_dai_hw_params on rt5640-aif1: -22
[ 86.196146] tegra-asoc: sound: ASoC: PRE_PMU: rt5640-playback-playback event failed: -22"
so does my code has some fault? how to modify it? please give me some suggestion.
