How to use csi camera in deepstream yolov3-tiny?
Thanks in advanced. I update source1_csi_dec_infer_resnet_int8.txt ‘model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b1_fp16.engine’ and run:
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo$ deepstream-app -c ../../samples/configs/deepstream-app/source1_csi_dec_infer_resnet_int8.txt
Creating LL OSD context new
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
      To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:163>: Pipeline ready
** INFO: <bus_callback:149>: Pipeline running
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 4
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=627200000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
**PERF: 29.29 (29.29)
**PERF: 29.07 (29.18)
**PERF: 29.06 (29.14)
q
Quitting
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
App run successful
GST_ARGUS:
PowerServiceHwVic::cleanupResources
I can’t see camera video window, would anyone tell me how to solve it? I’m trying to find where is imshow.
Duplicated with [url]https://devtalk.nvidia.com/default/topic/1061013/deepstream-sdk/how-to-use-csi-camera-in-deepstream-yolov3-tiny-/[/url]
Excuse me, I use nano, so I’m not sure which area is more suitable.
For issue is related with DeepStream SDK, please file into DeepStream SDK forum directly.
