Hi, I’ve tried to run oneshot example in tegra_multimedia_api, but it throws some errors like “no module”…sorry that I don’t remember the exact error message. Then I ran “nvgstcapture-1.0”, that it throws errors like below
bitrate = 4000000
Encoder Profile = Baseline
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingSocket read error. Camera Daemon stopped functioning…
gst_nvcamera_open() failed ret=0
** (nvgstcapture-1.0:1816): CRITICAL **: <create_capture_pipeline:4407> can’t set camera to playing
** (nvgstcapture-1.0:1816): CRITICAL **: main:5195 Capture Pipeline creation failed
** Message: main:5202 Capture completed
** Message: main:5252 Camera application will now exit
Also, I ran “gst-launch-1.0 nvcamerasrc fpsRange=“30.0 30.0” ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1’ ! nvtee ! nvvidconv flip-method=2 ! ‘video/x-raw(memory:NVMM), format=(string)I420’ ! nvoverlaysink -e”, then it throws errors like below
Setting pipeline to PAUSED …
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesrc.c(3354): gst_base_src_start (): /GstPipeline:pipeline0/GstNvCameraSrc:nvcamerasrc0:
Failed to start
Setting pipeline to NULL …
Freeing pipeline …
What should I do?
