How to use CUDA NPP library ?
I want to use the morphological image processing operations (dilation and erosion) which are provided by NPP library. What are the steps, the procedure I need to follow ? I am using Visual Studio 2013 with cuda 7.5.
Or at least I need help to understand how to use a library. Please help…
Try starting with and studying one of the NPP sample projects:
http://docs.nvidia.com/cuda/cuda-samples/index.html#freeimage-and-npp-interopability
I still can’t understand how to take a image, perform dilation or erosion on that and get the output image.
You might want to read the NPP documentation and see what functions are available.
http://docs.nvidia.com/cuda/pdf/NPP_Library.pdf
I don’t know what functions are involved in image dilation or erosion, or morphological image processing.
If you want someone to write the code for you, I wouldn’t be able to help you there.
