as title
Ubuntu 10.04
GTX285
CUDA Toolkit 3.2
I have a 5123232 array,
use C++ Standard Template Library vectors to build 3d array
and each element is double type
define t 512, kx 32, ky 32
vector<vector<vector<double> > > real(t, vector<vector<double> >(kx, vector<double> (ky)));
vector<vector<vector<double> > > dev_real(t, vector<vector<double> >(kx, vector<double> (ky)));
cudaArray *cuArray;
cudaExtent extent = make_cudaExtent(t, kx, ky);
cudaChannelFormatDesc desc = cudaCreateChannelDesc<double>();
cudaMalloc3DArray(&cuArray, &desc, extent);
cudaError status;
//=====HostToDevie=====//
cudaMemcpy3DParms HostToDev = {0};
HostToDev.srcPtr = make_cudaPitchedPtr((void**) &real, sizeof(double)*t, kx, ky);
HostToDev.dstArray = cuArray;
HostToDev.extent = extent;
HostToDev.kind = cudaMemcpyHostToDevice;
status = cudaMemcpy3D(&HostToDev);
if(status != cudaSuccess)
cerr<<"MemcpyHostToDevice: "<<cudaGetErrorString(status)<<endl;
//=====DeviceToHost=====//;
cudaMemcpy3DParms DevToHost = {0};
DevToHost.dstPtr = make_cudaPitchedPtr((void**) &dev_real, sizeof(double)*t, kx, ky);
DevToHost.srcArray = cuArray;
DevToHost.extent = extent;
DevToHost.kind = cudaMemcpyDeviceToHost;
status = cudaMemcpy3D(&DevToHost);
cerr<<"MemcpyDeviceToHost: "<<cudaGetErrorString(status)<<endl;
cudaFreeArray(cuArray);
for(int pge=0; pge<t; pge++){
for(int col=0; col<kx; col++){
for(int row=0; row<ky; row++){
cout<<setprecision(16)<<real[row][col][pge]<<endl;
cout<<setprecision(16)<<dev_real[row][col][pge]<<endl;
but the cudaGetErrorString(status) outputs
MemcpyHostToDevice: unspecified driver error
MemcpyDeviceToHost: unspecified driver error
real[0][0][0] = -2.838901364980553e-06
dev_real[0][0][0] = 0
real[1][0][0] = 6.81439681366683e-06
dev_real[1][0][0] = 0
real[0][1][0] = 2.912717275699299e-06
dev_real[0][1][0] = 0
real[1][1][0] = 6.001882060663956e-06
dev_real[1][1][0] = 0
real[0][0][1] = -1.416185500425027e-05
dev_real[0][0][1] = 0
real[1][0][1] = 1.276328002830376e-05
dev_real[1][0][1] = 0
real[0][1][1] = -2.871574757567012e-06
dev_real[0][1][1] = 0
real[1][1][1] = 7.496291361935671e-06
dev_real[1][1][1] = 0
